Question about Speed Queen AWS17NW Top Load Washer
Speed queen swt221wa top load washer knocking
Loud knocking when running
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: My Speed Queen washer is making a loud squeaky
Those brake pads are probably thin and not holding the tub like they once did AMANA WASHERf15820d.jpg
Posted on May 21, 2010
Testimonial: "Thank you for the great solution to my washer problem. The picture really helped."
MNfisherman
  • 11896 Answers
SOURCE: How do I change the transmission in a speed queen
http://docs.google.com/viewer?a=v&q=cache:vaSKIsbofmAJ:www.appliancepartscompany.com/apcocatalog/speedqueen/01-16speedqueen.pdf+change+transmission+in+speed+queen&hl=en&gl=us&pid=bl&srcid=ADGEESj7EkDCJJCpg2i9SS_9xB5sxQYCPAu03NMl-k09R4eea8Iz9JPec08BOsjyCYHJLazuAU0lVuxo9-fK5264w27_vjM76tKi4oTpo4wdGb7Hx-WysRTU_RlxPDeEdxy3hHIkk3yo&sig=AHIEtbS9byLtJXCiotxSA-LOYWSRQ9gi6w
here is a breakdown diagram if you need it.
Step 1 Cut off all power to the machine
Step 2 Turn off water supply
Step 3 - Drain Line If removing the drain and water lines provide more access to replacing the washing machine transmission, go ahead and remove it.
Step 4 - Water Turn off the water supply knob. In case you cannot find it then turn off the water supply lines till the job is completed.
Step 5 - Control Panel Take off the screws at the front end of the control panel. Use a screwdriver. Once the screws are removed, pull out the console and flip it free.
Step 6 - Unplug the Wires Locate the wires that act as harness. You need to unplug these wires. Use a flat ended blade to push the clips that hold the wires in place. This will release the wires.
Step 7 - Cabinet The next step in the washing machine transmission replacement process is, to lift up the lid and pull out the cabinet from the washing machine by tilting the machine towards you.
Step 8 - Screws After you remove the cabinet you will find an agitator cap. Below the cap are screws and bolts which are protected by a plastic cover. Unscrew the bolts and the screw to remove the agitator. This will reveal the shaft where the transmission is located.
Step 9 - Pump Remove the spring clips that hold the pump in place. Remove the two additional screws on the motor as well. There is no need to remove the hoses.
Step 10 - Freeing the Unit With the help of a flat tip screwdriver, take off the clip at the bottom. Make sure the motor doesn't fall off. Releasing the clip at the top will free the motor and the coupling from the washing machine transmission unit.
Step 11 - Installation Free the washing machine transmission from the frame. Make sure to remove the two bolts. Tilt and slide the unit at the bottom. Make sure not to damage any washers in the process.
Step 12 - Final Step After removing the old, place the new washing machine transmission in place by following the steps above in reverse order. Reconnect all the pipes and fitting. urn on the power supply, open the water supply and test the machine
Posted on Oct 25, 2010
caroldon
  • 17129 Answers
SOURCE: I have a Speed Queen top loader(older model). It
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Posted on Jan 13, 2011
  • 6277 Answers
SOURCE: Which top load Speed Queen
I think that you might be able to have an answer from the manufacturer.
Try its web site to see ;-0)
Hope this helps and good luck.
John C
Posted on Mar 11, 2011
How do I winterize a speed queen AWN432S top load washer?
you can,t winterize your washer in the first place any way okay
Nov 16, 2012 | Speed Queen AWN432S Top Load Washer With...
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen Model SWT220WA 3/4 filled with water, loud buzzing sound, stopped.
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
Aug 28, 2009 | Speed Queen SWT921 Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen doesn't agitate.
can i see solution that ziobob got on nov.08 2008
Nov 08, 2008 | Speed Queen AWS52NW Top Load Washer
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS17NW Top Load Washer Logo
46 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Coss
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
