Question about FUJIFILM FinePix S1800 Digital Camera
Hi,I don`t know what happened to my camera. I was taking photos and trying to zoom and sudenly my lanse was stuck. Now even if the camera is off the lens is out and I can not take photos at all. When
Lance stucked. Its out even if the camera is off.No posibility to take photos
  • 36 Answers
It sounds like the zoom motor has stopped functioning. You'll need to contact Fuji. Their warranty and service department can be reached at 1-800-800-FUJI (3854).
Posted on Mar 25, 2014
  • 11967 Answers
SOURCE: my lens is stuck out of my fuji camera says zoom
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
lock123
  • 6831 Answers
SOURCE: I have a Fuji Finepix S1500. It was dropped and
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
lock123
  • 6831 Answers
SOURCE: Hi, i have zoom error on my fujifilm camera does
Hello
Regards
Andrea
SOURCE: My Fujifilm S1600 freeze
you can try to reset the settings to factory,because it may be a wrong sett that you made.
best regards!
Posted on Dec 22, 2010
lock123
  • 6831 Answers
SOURCE: hi my j28 finepix shows zoom error and wont open,
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Apr 13, 2011
Sigma 17-50 2.8 EX HSM lens is stuck and won't zoom. It takes pictures Ok and sometimes it even focuses in automatic. I can also take pictures without zooming. Can someone help on how to fix.
Hi.
Probably the problem come from a loose screw inside zoom cylinder. Normally it happens due to constant use or vibration.
The GMR sensor is very sensitive to magnetized tools an needs an accurate position to function properly.
If you don´t have experiencie with this electronic systems, it is better you to contact Sigma Service in Ronkonkoma, N.Y.
Oct 17, 2015 | Sigma Cameras
CASIO EXILIM digital camera photo resolution
The Digimax A7 Doesn't work outdoors, because on top of the camera, try taking a picture, but hold your hand on the top of your camera (Cover it) it's light sensitive. On top their is a built in sensor, the Darker it is the darker the picture is, the lighter, the lighter. If you cover it, (Usually on top) It should work fine outdoor, just don' t cover it indoor. Hope this helped. -CA
Jul 14, 2008 | Samsung Digimax A7 Digital Camera
Shutter button wont work..it used to but even holding it down nothing happens
Hi, The camera functions normally in play mode and optical zoom also positions but can not take photos, to solve contact a service station, need to change parts.
Greethings
Feb 23, 2011 | Nikon Coolpix S3000 Digital Camera
Sanyo optical 3 x zoom s70 problem of no zoom out when switch on usb connection is display when switch on card reader pictbridge cancel. when any option is selected ok, nothing happens.
Hi there the question is not much clear. But i will inform you 1st the if you connect the USB with camera you can't operate the camera for photo taking . So zoom not working. But if you mean that as normally when you try to click photo with out USB connection but that time zoom or lens not working then try to do this.
Please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 27, 2011 | Sanyo Xacti S70 Digital Camera
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Can't take pictures when using zoom.
this unit need factory repair I hope you have a warranty I'm very sorry I would try calling the manufacture and explaining this to them. Good luck
Sep 16, 2009 | Cameras
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Elura 60 doesn't take still pictures
I had a similar problem with zoom being stuck and also not being able to take a still. I tried the suggestion of whacking it in the area of the zoom and photo button and it started working.
I just tapped it with two fingers. Sounds odd but it worked. good luck
Sue
Jun 04, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Shuts down while using the zoom lever
see this thread :
http://www.fixya.com/support/t225803-canon_powershot_s3_switches_off_when
Mar 21, 2008 | Canon PowerShot S3 IS Digital Camera
Olympus Digital Camera D-490 zoom will not take pictures outdoors
It sonds like teh shutter is stuck open. If the camera is indera year old it is probably still under warranty. Take it to an authorized repair shop and they will most likely repair it for free.
Sep 25, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
FUJIFILM FinePix S1800 Digital Camera Logo
56 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
