Rust build up along lid of Maytag Bravos washer
A rust spot is developing where the top of the washer meets the bottom part of the machine. I want to know how I can clean off the rust and repaint it.
lscf150
  • 443 Answers
SOURCE: washing machine insert is rusting
You should contact Kenmore, most inner wash tubs came with a lifetime warranty, you would have to pay for the labor but they should cover the part. Good luck !
Posted on Jan 05, 2010
  • 1937 Answers
SOURCE: rust under lid and top of barrel.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0117d74bc3bdabe782b54341ddab128a
Posted on Jan 19, 2010
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
  • 10 Answers
SOURCE: Every once in a while a plume of rust get injected
No depending on your citys growth rate and repair rate of the lines underground this happens to homes everyday. Another real possibility is your water heater you have not replaced. put an inline water filter on and you will be happy 2 ways no rust and better feeling longer lasting clothes
Posted on Jul 23, 2010
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Need to remove the glass lid to get to an area of rust caused by a maytag technician chipping the paint and they won't fix it
Tape the washer lid closed. Using a putty knife, press and unlock the two front top locks. The locks are approximately six and a half inches from the outside edge of the washer
Mar 10, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Maytag bravos mvwx500xw0 has no power after closing lid
You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
Jan 12, 2013 | Maytag MVWX500XL High-Efficiency Bravos X...
Every once in a while a plume of rust get injected into the washer or rinse cycle. Are their components on this washer that can develop rust for this to happen? The model # of this Whirlpool machine is...
Jul 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Have had numerous items ruined due to brown stain
My Maytag Front Loader also has periodically caused rust stains on clothes. After investigating it I determined the cause.
The top of the machine is rusting around the opening under the lid where you add the detergent, fabric softener, and bleach. Water apparently splashes up on the bottom of the lid and it rusts. The flakes of rust then flake off and fall into the plastic reservoir and are washed into the machine. The only fix is to replace the top of the machine, or take it off, physically clean off the rust and apply a coating of rust resistant paint to the inside. A quick fix is to remove the plastic cover (4 phillips screws) and clean as much rust off around the edges as you can. Be sure and keep the rust from falling down the hole where the water flows into the machine.
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Sep 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
