Question about Philips Audio Players & Recorders
Vw delta 6 code
I need code for delta 6 vwz4z4d5073319
Radio code for my 2003 vw jetta premium 6 radio
If it is not in the owners manual you will likely need to provide the vehicle vin # and registration to a VW dealer Parts Department and they can call it in to the manufacturer and get it for you.
Apr 10, 2017 | 2003 Volkswagen Jetta TDI
I need the firing order for my 1988 delta 88 v6
Please don't forget to rate....hope this helps you!
3.8L (VIN B and 3) Engines Firing Order: 1-6-5-4-3-2 Distributorless Ignition System
3.8L (VIN C, 1, L and K) Engines Firing Order: 1-6-5-4-3-2 Distributorless Ignition System
Sep 14, 2010 | 1988 Oldsmobile Delta 88
I have a Delta Luv Crib Model 4885, Order No. W24255 Date Nov. 2004. Is there a recall on this crib?
Luckily I didn't see your model listed in Delta's Crib Recall. Below is link to Delta's website and a list of all Delta cribs recalled.
http://www.deltacribrecall.com/
If this information is helpful, I would really appreciate a "thumbs up" rating!!
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
Aug 10, 2010 | Delta Luv Delta - Baby Products 5-in-1...
I need vw passat 6 radio code,serial number radio-vwz3z3a7746697
Sorry...Main VW Dealer or a Radio decoding service only for this code as access is required to the factory database which is not commercially available as software
Jul 26, 2010 | Volkswagen Car Audio & Video
Spark plug wire connection from plug to my coal pack,needs to know how it goes in right order
1988 Oldsmobile Delta 88 3.8 liter V-6 VIN "C"
1988 Oldsmobile Delta 88 3.8 liter V-6 VIN "3"
Hope helps (remember rated this).
May 30, 2010 | 1988 Oldsmobile Delta 88
I need to find blades to fit a delta 6" X5 jointer, model 37-866x
go to Dewaltservicenet.com and under the service locator on the right hand side type in your information. The blade set number that I came up with is 37-658 and they show that as qty 3 in one package.
Mar 19, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
I have a 14" delta bandsaw ser. no. 6-5560 It is a 2 speed it has a 6 sided guide post and a 4 part cast iron base that comes apart with thumb screws I am looking for the model number
From information over at http://www.deltaportercable.com/ServiceAndSupport/OwnersManuals.aspx
"You can locate your product's model number on the warning/caution label on the product itself."
It's often a two letter code followed by a dash then a 3 or 4 digit number. some examples are PM-1886 or BS-3A or 28-701. Hope that helps!
Dec 16, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
10'' delta table saw manual
you might try Dewaltservicenet.com but you will need the model number and you might have to put the dash in between to get it to list the model. Let me know if you need more assistance and if you do I would also need this information.
Nov 27, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Changing voltage on motor...
pull up the i.s. wiring code from that time
i.s. international standards.
the code change a few years ago
Apr 09, 2009 | Delta Radial Arm Saw
Where to purchase Stabilizer Bars for Delta Luv Crib #4750-6?
What is wrong with the stabilizer bars that came with the crib? If they broke or fell apart, you should report that to the CPSC as it could be a safety issue.
Jan 12, 2009 | Delta Luv Delta - Baby Products 5-in-1...
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
