Question about Samsung Televison & Video
My Samsung LE32R88BD keeps resetting itself to dynamic and DBLe demo keeps coming up on the screen with off and on at either side. TV has worked 100% until this morning so i don't think its the capaci
TV keeps turning off and resetting itself
SOURCE: Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Posted on Jan 22, 2009
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
SOURCE: (Built in) TV GUIDE Screen is black except for small channel preview window on top-left.
After purchasing a "service remote" and then buying a new "Main Board-Analog" which didn't fix the problem, I spoke with tech support who then emailed me an "EPK" file. Basically the computer board inside the television needed to be updated since this whole digital conversion is happening.. However this incident has given me tremendous knowledge of what to do and how to troubleshoot and how to reset my own TV with all the hidden menus that you never knew you had. Don't be tricked into buying a mainboard or even paying a diagnostic fee. If your TV GUIDE screen goes blank and all you see is a small channel preview screen in the top left corner, chances are all you need is the EPK file update. I received the update file in my email, I downloaded it to an SD card, inserted the SD card into my 32LX1D LG LCD TV and it did the rest. It was too easy. Most newer LG TV's are coming with a "SERVICE USB" so you can attach a "jumpdrive" or some other storage to it. These so called "Authorized Service Centers" are a hoax. WHen you bring your TV into them they charge you a "diagnostic fee" ranging from $50-$150 just to diagnose it, then they tell you that that can also be applied to the cost of the repair. All the service center does is call a special priviledged tech support 800# for LG to find out what to do. I've replaced and removed my own Main board. You gotta learn the game people, its all a big game to keep the revenue coming long after the sale of the TV. Which is why nowadays automobiles are manufactured with parts that were made to break intentionally to keep bringing you back.
Posted on Apr 30, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: My Samsung LNT3253H LCD TV has suddenly started
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Posted on Sep 05, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
Hi my Samsung dv3 Model no: le32r88bd keeps reseting its display mode to dynamic, with a horrible backlight. Every time I reset it to standard or cinema and deactivate the backlight it resets it self...
The television is doing that because it was either the display model at a store or when it was set up store mode instead of home mode was selected. What needs to be done is for the intial setup to be redone with home being selected instead of store. The tv resets to dynamic for optimal viewing when on display next to other televisions in a store.
Aug 23, 2011 | Samsung Televison & Video
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
It keeps saying d.i.s.t dynamic gamma off on and also non of the buttons work. and my remote doesnt work and my tv is in mint condition
JVC has a menu function called Auto Demo that displays the image with and without Dynamic Gamma. Find this feature in your menu liast and turn it off.
Oct 21, 2010 | JVC AV-27530 27" TV
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Samsung LCD picture adjustment... Store Demo...WTF...?
Push the volume button on the television set (not the remote) up once.
Then press the menu button (TV, not remote) for about 12 seconds.
It should flash once and go to dynamic mode (center, bottom of the screen), which will indicate that it is now in the "non-store-demo" mode, allowing you to save your picture settings, and access the menus.
Sep 24, 2008 | Televison & Video
Picture resetting itself
you need to make reset in service mode
Jun 11, 2008 | Samsung Televison & Video
Televison & Video Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
