When car is turn on breaks go to floor
My breaks are ok when car is not running but when car is they go to floor
    Master:
  • 435 Answers
Check your brake fluid. Call a shop and do not drive it like that.
Posted on Apr 27, 2014
Fix soft break peadel on 2006 ford feestar van is hard with eng off soft wene running
Sounds normal to me. If it doesn't go to the floor ,you may be ok. They were notorious for the rear wheel cylinders seizing. You may have air in the system from a previous repair ?
Feb 20, 2015 | 2006 Ford Freestar
Www ehow com
It is possible you have a leak or air in the brake system, a leaking brake booster or low vacuum/ leak in the vacuum line going to the brake booster. The engine vacuum is what assists brake pedal operation. When the engine is not running, you are able to build up pressure more quickly because the booster is no longer assisting the relief of pressure. Basically the pedal just feels more stiff, but it does not guarantee better brake function. Brake issues should be inspected by a professional as this can be a major safety issue.
Mar 24, 2014 | Computers & Internet
Gear shift stuck in park
You should take your car back to the person or place that you fixed it and tell them it is worse than before. Insist on getting your money back if it is not fixed.
Jul 12, 2017 | Ford F-250 Cars & Trucks
I just replaced the shocks in the front of my 1991 Tracer, went for a test run, shocks are fine, brake pedal went all the way down to the floor. Now the brakes seem to be ok, are the brakes ok? What caused...
It sounds like air in the brake line. No,it is probably not ok! They sell a one man break bleeding kit! Bleed the system and replace lost brake fluid.Check all the brake lines for damage,as well.
Oct 20, 2012 | Cars & Trucks
Brake peddle is ok when car is not running.peddle goes to floor when engine is started
sounds like you need major break work. Check the pads, rotors and also the brake booster and master cylinder.
May 05, 2011 | 1997 Volkswagen Jetta
Keep getting air in break lines
1. bleed your vehicle while the engine is running. 2. Check ALL your brake lines, connections and wheel brakes cylinders or calipers of any leaks or moisture. 3. If nothing happens, your brake masters or your caliper's pistons may be weak and needs replacement.
post me of any development
Dec 09, 2008 | 1987 Mercedes-Benz Mercedes Benz 500 Class
Breaking
there is a big rober hose by the power booster start the car up and then turn the car off then unplug the hose if you hear like air the the booster is ok but if not then most likelly the powwer booster is not good
May 27, 2008 | 2002 Pontiac Grand Prix
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
