Trying to install tp link w8980 on to plusnet fibre broadband
Dont know how to put settings in to router
  • 3,320 Answers
It's an ADSL router. Look at actiontek for fibre routers
Posted on Apr 13, 2014
Cameron07
  • 110 Answers
SOURCE: D-Link Ethernet Broadband Router
What I would do for the computers that can't get internet connection. Basically just connect to it wirelessly with a wireless adapter that I talked below,
1.I would go buy some "USB" wireless adapters you can get them for $15-25.00 USD
Linksys carriers ones that I use,heres a link to what it looks like.
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1115416827517&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=2751739789B16
that is the one I use for my Desktop.
Once you get those setup and install the drivers with the disk that come with the wireless adapter you just connect to the router wirelessly.
Posted on Oct 17, 2007
2Gigs
  • 141 Answers
SOURCE: Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Posted on Mar 15, 2008
SOURCE: d-link DIR-635 router
How I have solved my problem with the wired computer to a DIR-635 router:
- downloaded latest firmware from ftp.dlink.de/dir-635/driver_software (as posted here before)
- reset the router ( keep just the power cable connected to the router, press the reset button and switch off/on while holding the reset button pressed, off/on again with reset pushed down, release reset button, connect LAN cable between PC and router, access router 192.168.0.1 and all the configuration using the wizards)
- while configurating your Internet connection (I have the wizard option) it is important to use the option "clone MAC address from your PC", the one you used to connect direct to the cable modem.
- Follow next common steps to configurate your wireless network, etc.
Right now I'm having my PC wired to the router plus three other desktops via wireless and a wireless Canon printer.
Everything is working fine, no network drop, no internet drop. Perfect as it used to be.
Posted on Jan 06, 2009
SOURCE: D-Link DIR-635 Wireless N Router won't install
hi! I will be more than glad to assist u in this concern. I encounter that problem as well. I have a dlink as well. I follow the cd installation and it wont detect the modem or internet. but if the computer is connected to the modem it works..what i did. i didnt follow the cd installation, I set it up manual by typing at the url of your brower, 192.168.0.1 that is the ip add of the router and it will ask the username and password, by default the username is admin and the password, just leave it blank..in the setup page, select on manual internet connection setup.. there is an option for dhcp-which is auto detect, static ip or pppoe. but first check what kind of setting u have with ur isp, if u are using a username and password, u have to select the pppoe, if the isp provide gave u a static ip address u have to select static.. to know your ip address settings, click start, run and type cmd and it will show dos prompt, from there type ipconfig/all, it will list the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Posted on Aug 09, 2009
govinda123
  • 2260 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
I want to connect to BT broadband using my TP-Link TD-WD8901G routerg
Sounds like you need to change the TP link router for a wireless Access Point or a range extender.
Who knows what goofing around BT does with their equipment.
Mar 20, 2014 | TP-LINK TL-WR642G Router
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
How to configure TP-link TL-wr340g on tata broadband
If you don't have any internet access, you can reset the router by unplugging it from power and then plug it back in. Do the same for your ADSL or cable ISP modem which you have connected on your TP-Link router.
RESET FIRST YOUR ADSL MODEM and then your router.
Other solution might be to do ipconfig /release and ipconfig /renew on your command line window from your computer.
You can find your wifi router's user manual (PDF) on this link:
http://www.tp-link.com/resources/software/200943083466.pdf
Please mark as solution if this helped you at all.
Thanks.
Jan 29, 2012 | TP-LINK Computers & Internet
After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Nov 20, 2011 | TP-LINK TL-R480T+ Broadband Router 2xWAN,...
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Setting up for broadband
First, you might want to check with Plusnet the login information and the type of the authentication they have. Secondly, setup your router, login to your router using a web browser. Type 10.1.1.1 in the address bar and press enter key.Login using the default setting username 'admin' and password 'admin'.
Click on Home tab and then on WAN on the left side of the screen.Select PPPoE/PPPoA option.Under Connection Type select 'PPPoE LLC' in the drop-down menu.Enter username and your password.Please check with your provider if not sure again.
If you have connection with static IP address, you do not have to specify the IP settings on the router: the router will be getting the same IP from your ISP every time it connects.Click on Apply. To save the settings into the router's memory go to Tools > [System] > Save and Reboot.Give the router a minute or two to reboot and reconnect.
Lastly, Restart your computer and you should be able to access the Internet.You do not have to run any login client on any of your computers because your router logs to your ISP automatically.
or check this URL;
ftp://files.dlink.com.au/products/DSL-502T-GenII/Manuals/DSL-502T_GenII_Manual.pdf
Jun 12, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
