Question about Curtis DVD1041 Player
Screen is red
Video works ok but screen is red, sometimes black and white
    Problem Solver:
  • 6 Answers
Replaced the main board.
Posted on Mar 25, 2014
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
Picture for Wii game is in black and white only.
What type of cables are you using? My presumption is that you're using Component Video Cables - Red, Green, Blue for video, Red & White for audio.
If one of the 3 video cables is mixed up or poorly connected, you could see a Black & White image on the screen. I suggest double checking your cables for tightness and correct color attachment. Also be sure the red video is not mixed with the red audio cable. The red audio cable is marginally thinner and probably physically attached to the white audio cable.
May 05, 2011 | Nintendo Wii Console
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Wii video is black and white
Possibly you've plugged the video into the component (RGB) portion of the input - this calls for 3 connectors (Red, Blue, & Green) and if you only plug one in from a composite it comes out grayscale. If you only have one video lead (yellow connector) make sure it is going to a composite connection which should also be yellow. Otherwise, more info is needed about your connections.
Nov 02, 2008 | Nintendo Wii Console
Rel Q50 SPEAKER
This is very easy. The Red and Black(Sometimes white) are for your Audio Usually Left and Right respectively. Yellow is for Video let me know if that helps. there are some instances where if you plan to hook it up to a Television, specially the older ones, you'll find that you just have two inputs for only two cables so what do you do then. Well... Just hook up the yellow for the Video Par and Either the black or Red leaving one unused. Let me know how that works out for you alright. And feel free to ask more questions where we will be more than happy to assist you.
Oct 02, 2008 | Audio Players & Recorders
Black and White Video - Wii Component cable
put yellow in video red and white in audio and change source to av
Aug 16, 2007 | Nintendo Wii Console
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Curtis DVD1041 Player Logo
27 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
