Question about Cameras
My slick simpleflix digital video camera keeps saying card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Mar 24, 2014
SOURCE: Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Posted on Jul 11, 2008
VOTIT
  • 2071 Answers
SOURCE: card locked
Card lock means that someone switched the little gray sliding lock on the memory card. It prevents the camera from saving new pictures to AND copying pictures from the card. All you have to do is take the card out and slide the little gray slider back into the unlocked position. Take the card out of the camera. On the side of it is a little 'switch'. Flip the switch in the opposite 'unlock' position
1)check the card to make sure the write protect switch isn't on the wrong setting. It's on the side of the Secure Digital card (not memory stick).
2) I hope you're not buying Memory Stick. That's for Sony. You should be buying support digital.
3) Check the card contacts--if the card isn't making good contact in-camera, you'll get hold of card errors. This happens when someone touches the contacts on the card. Usually cleaning will work unless something sticky get on it. Most memory cards do have exposed contacts, so you enjoy to be careful when handling them ...
4) Format the card in the camera if you grasp an error message. It may just entail to be formatted.Your battery is always drain quickly, that’s symptom of the battery near to run out.,it’s better to change it, your owner's manual say that Lithium AA's will work well and later almost as long.
Hope this may help….
Hope this may help;
DON'T FORGET TO RATE:
Posted on Aug 25, 2008
guru_dev
  • 315 Answers
SOURCE: my camera keeps saying card locked and its not
Okey, this can be tricky, but it worked for me.
I have Canon Ixus 60 and Kingston SD 1gb memory card.
After loading set of images on my laptop and putting the card back in to camera, screen displayed "Card Locked!" message.
I did everything to check the common flaws, but still the same message occured.
Material needed:
1 paper clip
The socket for memory card has this tiny detector for sensoring if the card is locked or not (same side as the lock switch on the MC). For some reason it was sticking out from the side. So, little fiddling with paper clip to put the detector back in and another try to put the camera on, everything worked out just fine.
Posted on Jun 30, 2009
xscrewdriver
  • 246 Answers
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Posted on Jul 02, 2009
daniel_2489
  • 63 Answers
SOURCE: How do you unlock your memory cards for your digital camera?
take a look at the card it should have a switch on the side just slide it and it should be unlocked
Posted on Aug 01, 2009
How do I download photos to my PC from camera?
camera should have a sim card-should open a small door bottom of camera-push card in and should pop out-put in your pc-should be slot if laptop-front of box for a desk top- computer will ask you where you would like to save them(pictures) to on your computer-good luck
May 05, 2015 | Slick Products Slick Digital Camera
Need manual for simpleflix camcorder
There are manuals for three different model Simpleflix camcorders here.
Mar 26, 2012 | Video Cameras
My nikon coolpix s4000 can't read the memory card. Why
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Your problem carries all the hallmarks of "your card isn't fast enough". Check your manual to see what speed of card is required for HD video. If it doesn't say, try a card that says as least "Class 10" or "10Mb/s" or "66x". If you set the movie resolution down to 640x480 it has a better chance of working
Keep us updated.
Apr 02, 2011 | Nikon Coolpix S4000 Digital Camera
I have a SimpleFlix / Digital camara Model #VC120BK-GB What memory card do I need. Also what are the prices for these memory cards? 4GB?
my disc to down load to computr is broken .i need to down load copy to install vc12bk-gb
Dec 22, 2010 | Cameras
L100 Digital Camera: keeps saying card locked...
May 17, 2010 | Samsung L100 Digital Camera
Keeps saying card is locked
Hello
OK, if your camera keeps saying that the card is locked, you need to take your memory card from the camera.
The card should look something like this. Have a look at the lever on the card, which will lock or unlock the memory card for use.
Now, just slide the switch to the other end to unock your card.
Let me know if you need any further assistance.
Kind regards
Andrea
Feb 21, 2010 | Samsung S860 Digital Camera
My samsung camera L313, Keep saying card Locked
  • connect it to the computer
  • look weather threis any hidden or zipped file or folder
  • if any unzip it or unhidden it
Nov 04, 2009 | Samsung L100 Digital Camera
Hp photosmart that keeps saying card locked when inserted
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 17, 2009 | HP Photosmart M447 Digital Camera - Silver...
Memory card locked
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
