Question about Sony PlayStation Portable (PSP) Console
The stick analogique moves by it self
If i have the 2 screws on the backside of the PSP System on the side of the analog stick. If either of the screw is loose what i must do
  • 34 Answers
Does the stick return to the center position when not in use or is it loose? If it won't return to the center position, then the stick will most likely need to be replaced. The PSP has to come apart for you to replace the stick. As for the 2 screws being loose? You would have to more permanently put them in, but then you may not be able to get them back out.
It is also possible that dirt/dust has gotten into the joystick area and is causing problems.
Posted on Mar 25, 2014
Psp
Did you buy just the thumbstick or the whole mechanism? Did you take the machine apart to install anything?
Mar 24, 2014 | Sony PlayStation Portable (PSP) Console
My psp anolog stick is not working when i try to move it up+left what do i do
To calibrate your analog stick, go to the system information screen on your psp, and move your analog stick around in a circle as far out as possible.
May 17, 2011 | Sony PlayStation Portable (PSP) Console
Drifting ananlog stick and umd disk reading problems
A drifting analog stick is usually the result of a loose screw on the PSP shell.
If you flip your PSP over so you are looking at the back of it, there will be two screws on the side where the analog stick is, try tightening both of those screws (specifically the bottom one) with a small screw driver. If the problem persists, you can try to replace the analog stick yourself if the warranty has expired. If your warranty is still valid, you can send your PSP to Sony and they will repair it for you.
The UMD drive on the other hand, may be the result of dirty laser, or failing drive. Depending on the age of the PSP, you may be out of luck. The only option, aside from replacing the drive (which is expensive, and well, not worth your trouble) is to jailbreak your PSP to be able to play games from the memory stick. While downloading games that you do not own is illegal, backing up the games you own is ok.
May 16, 2011 | Sony PSP (Piano Black)
My analog move on it"s owne
This is usually the result of a loose screw on the back of the PSP behind the analog stick, or dust on the analog stick receiver itself. If it is an older PSP, you can try to open it up and clean the analog stick yourself (after tightening the two screws behind the analog stick, of course) but if your PSP is newer, I wouldn't recommend it, because any attempts to open the PSP will VOID YOUR WARRANTY (if you still have one).
BE CERTAIN YOUR PSP WARRANTY IS NO GOOD BEFORE YOU ATTEMPT TO TAKE IT APART YOURSELF AS YOU WILL VOID YOUR WARRANTY.
Open PSP 1000: http://www.ehow.com/how_6085376_open-psp-1000-repair.html Open PSP 2000: http://www.ehow.com/how_6548290_open-2000-psp.html
May 16, 2011 | Sony PlayStation Portable (PSP) Console
My psp analoge stick was move in her self.
your button pad may be get damaged , take your analog stick to shop to get new one ...
if you want to repair it by your own, you can use repair guide... it will give you the way that how to fix this problem.....
click here to download........
Oct 05, 2010 | Sony PlayStation Portable (PSP) Console
My psp's analog stick is not working properly one
hi thanks for using fixya!
On this kind of error, I recommend that you bring your psp to a service center to further check that contol analog stick.
Regards!
May 12, 2009 | Sony PlayStation Portable (PSP) Slim...
The analog works fine in the options menu but when
Try calibrating your PSPs analog stick, here's how: 1. Go to Settings>System Settings 2. With the System Information screen displayed, rotate your analog stick in a circular motion (clockwise and counter clockwise). This will adjust the analog stick's range of motion. 3. Exit the Settings then run your game and test the analog stick. (it should be working well by now)
I hope this helps.
Apr 12, 2009 | Activision Video Game Consoles & Games
Psp moving on It's own
when you replaced the joystic was it just the little top part or the whole joystick?
Apr 17, 2008 | Sony PlayStation Portable (PSP) Console
Psp moving by itself
Hey, looks like your PSP may have one of these two problems. There are 2 screws on the backside of the PSP System on the side of the analog stick. If either of the screw is loose then the analog stick will move by itself.
Second problem is the Analog Stick itself has been damaged. You can replace these very easily if you are good with tools and electronics.
Bimmerhp
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
