Question about Pool & Spa
Pellet stove cc franklin 120 hcf 120, was running, then died! ACUTRONII
Lights flashed on circuit panel, then just quit!
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
SOURCE: 5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Posted on Feb 07, 2010
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
WHAT DOES ER2 CODE MEAN ON PELLET STOVE
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
I have a Quadra fire 1200 pellet stove insert. The convection blower does not stay on continuously. 2 min on 2 min off
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Jan 02, 2010 | Kitchen Appliances - Others
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Cheap charlie pellet stove/pel-pro runs for 10min then shuts down
The auger is controlled by a T-stat on the side of the combustion chamber. Open the side of the stove and you can see the auger motor and the thermostat that feeds it. It has a manual reset button on the back of the thermostat, press it.
Jul 05, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Mar 11, 2009 | Napoleon Auburn Pellet Stove Heater
Pool & Spa Logo
131 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
