Question about Samsung WA456DRHDWR 4.5 cu. ft. High-Efficiency
I have a Samsung WA456DRHDWR. The drain pump went bad. I wasn't around so I don't know what happen but when I found it the pump had busted out of its' plastic mounting bracket and the 2 wires were dis
My wife found water leaking from the bottom of the washing machine. She shut everything down. I found the drain pump had busted out of its plastic housing and the hoses and wires had become disconnected. I replaced the pump assembly. I then leveled the machine and put water in the tub. I put the machine on spin only and the pump worked fine. The problem is the pump won't quit running. Even if I unplug the machine and then plug it back in the pump will start running as soon as the machine is plugged in and before the power button is pushed. Any ideas?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
2 possible problems:
1. there is a tiny switch in the lower metal base of the machine hit it it might be stuck.
2. you have a problem with an electronic component in the main pcb called triac. this part is acting as a switch you need an electronic repairer to change it
Posted on Mar 24, 2014
Sea Breeze
  • 4654 Answers
SOURCE: Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Posted on Jun 19, 2009
  • 93 Answers
SOURCE: door not locking
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
Posted on Sep 12, 2009
SOURCE: water will not pump out
Before you replace the pump; check to make sure there is no debris in the pump or hoses. I just pulled a baby sock from inside the impeller part of my pump.
–It was an easy repair. Just unplug your machine. Remove the back access plate (2 screws). Disconnect the hoses (be sure to have towels handy – you may have up to 12 gallons of water drain out –I had about 2 gallons). With a flashlight inspect the impeller, if there is debris -it is most likely your culprit.
Posted on Mar 04, 2010
SOURCE: Spin dryer on my twin tub washing machine does
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Posted on Nov 07, 2010
richroth
  • 9472 Answers
SOURCE: washing machine quit working wont
ND is for a "No Drain" error Watch the video below to show you how to clear the filter.
Posted on Jan 10, 2011
My Samsung washer model WA456DRHDWR/AA doesn't have any power. Need help troubleshooting.
Hey Cindy,
First, makes sure all the breakers have been reset and do not trip when you try to use the washer.. if the breaker trips each time you try to use the washer, then you need to cal a qualified repairman..If the breaker is good and stays on, make sure its plugged in correctly..if its plugged in and you have power at the plug..( are you mechanically inclined?).. if not call the Qualified repairman)..there are several things that will cause it not to work,,
Samsung WA456DRHDWR AA User Manual Check These Solutions If Your Washer...
http://www.appliancepartspros.com/repair-help/samsung-washer-wa456drhdwr-aa-0001-repair
check this out..
Samsung Recalls Top Load Washing Machines Due to Risk of Impact Injuries
Sep 11, 2017 | Samsung Washing Machines
I have a Samsung front load washer and recently we've had an onslaught of problems. First the control board went bad displaying pf fixed that with a replacement,, then a couple days later displayed nd so I...
nd means "no drain", so your fixing attempts seem to be ok so far. Maybe there's a problem with the wiring. Vibration may damage cables or lugs (eg. a badly crimped connection). It's often hard to spot though. Is the pump making "sane" noise?
Feb 24, 2015 | Samsung Washing Machines
My drum has come loose from the bottom where the agitor is how do I get it apart so I can center it again?
I would guess that the bearing is loose or bad.If you lay it on its side you should be able to see whats wrong
Oct 05, 2014 | Samsung High-efficiency Top Load Washer...
I have changed my fuel pump about 6 months ago. But it was a used one. Anyway my truck started driving bad and my check engine light would blink on and off and at times would stay on. But it didn't...
You can have someone stand by the truck and they should hear the pump kick on when you turn the key in the on position. Can you spray fuel into the throttle body and will it start that will tell you if the ignition is ok or not and also tell you if you have fire to the cylinders. If it start right up and shuts off you either have a bad fuel filter, fuel pump or a plugged catalytic converter in the exhaust system.
Jun 10, 2017 | 1999 GMC Sierra 3500
Just got a model 9 hottub and everything was working fine but now blower is coming on but nothing happens, i know it has warranty just wondering what the problem might be?
I have a customer with the same problem on a below ground pool's blower. I took it apart and found the motor for some reason was not turning the blower fan or was blocked. It has been quite a while so I don't remember exactly what I had to do to put it right but it wasn't hard. I hope yours is easy also.
Sep 14, 2011 | Qca Spas Paradise Hot Tub
I HAVE A 1994 PLYMOUTH VOYAGER. 3.0 ENGINE. A MONTH AGO IT STALLED AT A STOP SIGN AND WASN'T GETTING ANY GAS. IT WOULD CRANK BACK UP BUT STILL WASN'T GETTING ENOUGH FUEL TO RUN. I HAD IT TOWED IN...
The worst case would be a failing fuel pump (they tend to be pricey, and are a pain to change).
Another possibility is contamination in the fuel tank such as dirt, rust flakes or solid products of fuel degradation - this would clog up the new fuel filter very quickly. It wouldn't be good for the fuel pump either. Check the tank for signs of corrosion, especially around the filler tube. A quick test of the filter is to disconnect the outlet side first - if you get just a dribble of fuel out of there, then a good stream of gas from the inlet side, that is an indication of a clogged filter and therefore a tank problem. You could try to siphon or pump a sample of fuel from the bottom of the tank through the filler tube for inspection.
A third possibility is a sensor or computer problem. It seems unlikely a single-point failure would take out all of the injectors unless it's the injector power common. Maybe the engine computer uses a single buffer chip to drive the fuel injector transistors, or there's a bad power bypass capacitor for the injector power. Engines don't usually stall on sensor failures - they keep running, but often with degraded performance, and you'll get a check engine code. Check for voltage on the fuel pump relay before changing it - when the engine is on, there should be 12 V on the coil, and 0 Volts on the contacts. If you get voltage across the normally open (NO) contacts when the coil is energized, the relay contacts are bad. (The tricky part is getting at the relay socket terminals with the relay in place.)
Jun 20, 2011 | 1994 Plymouth Voyager
My dishwasher won't drain and there is a rattling noise in the door. I don't know if I should just get a new one as the repairman costs are high. I did start a cyle over and more water went in but...
there is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Jun 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
2000 acura every now and then, car would idle rough when started, yesterday car wouldnt start at all. so i waited and tried again a few times, then i pumped the gas a little to get the rpms up and once i...
I have a 2000 TL as well. Had a VERY similar situation. It wasn't a constant problem and ran fine between times just like you said! Frustrating!
It wound up being ONE coil that was starting to fail. www.acurazine.com is a wealth of info.
Bought one coil and held onto it until next time it ran bad, then went around the rows swapping out the old coil for the new one... one at a time, until it ran right. Then I knew I found the bad coil.
Don't know if this helps, but sure hope it does!
Apr 09, 2011 | 2000 Acura TL
Flooding on my 2001 426
High performance parts do not cause the leak on other bikes. sounds like it is the needle and seat is not sealing or the o-ring around the seat is bad.
May 25, 2009 | 2001 Yamaha YZ 426 F
Samsung WA456DRHDWR 4.5 cu. ft. High-Efficiency Logo
108 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
