Question about OKI B8300 Laser Printer
Get message: Call for service
Called OKI and the only thing I got out was that it could be Heat Roller Low Temp.
Anyone with any ideas what is wrong with the printer any suggestions or thougths will be welcomed and appriciated.
Thank you in advance.
  • OKI Master
  • 1,113 Answers
H4-01 Heat roller low temp is correct.
You machine has a fuser unit that it uses to bond the toner to the paper, it does this with  a heater lamp heating a set of rollers that the paper passes threw after it has printed.
Your machine monitors this unit to regelate its temp, your machine is sensing via a thermister and thermal fuse the temp of the fuser unit is not hot enough to enable use, this would mean the heater lamp is blown, thermister is faulty or thermal fuse blown 95% chance it's the lamp,
What one normally does is replace fuser assembly with new this is not a user thing it requires a tec, but if your into it, it is the hi voltage hot bit near paper exit.
Posted on Oct 31, 2007
My oki b 4600 print one page then get jamed paper how i can fix this problem please help me
Age and wear can make a roller shiny and so, slippery, and so cause bad paper feeding
To fix a shiny roller, rub it down with a coarse nail file which yes, will often involve stripping the machine, at least partly.
Consider also, how much would a new machine cost, and take into account that such a thing would come with new ink
Oct 01, 2016 | Oki Data Americas, Inc. B4600 LED Printer...
How do I print multiple booklets?
It may be specific to your OKI printer driver. Refer to it's manual.
Apr 24, 2015 | OKI Office Equipment & Supplies
How do I fix the "change toner cartridge" error.
Has the cartridge got a chip? Does this chip need replacing?
Feb 11, 2015 | OKI B8300 Laser Printer
Our Oki 8300 printer has an errror code L4-02. What does this mean?
I have an error code L4-02 with Oki B8300. what is the solution?
Oct 28, 2010 | OKI B8300 Laser Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
OKI B8300 Call for Service error
Here is a link to service manuals for OKI
Feb 07, 2008 | OKI B8300 Laser Printer
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
OKI B8300 Laser Printer Logo
290 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
