Question about IBM Infoprint 1585n Laser Printer
IBM Infoprint 1585 folded corners
We have a machine that is folding the corners of printed pages. We have replaced the fuser and a few other parts to try to stop it from happening and it keeps doing it. Always in the same corner but not on all pages... please help... we have the repair person here and are not having any luck.
  • 300 Answers
SOURCE: ibm infoprint 1332`
It's quite straight forward
1. Remove the left door.
2. Remove the right cover
3. Remove the paper support
4. Remove the redrive cap
5. Press the fuser wiper cover latch and remove the cover.
6. Remove the top cover screws
7. Remove the paper bin full sensor flag assembly from the mounting bracket
8. Remove top cover.
9. Remove 3 screws and the cables, the printhead will now come out.
10. After replacing the printhead run some test prints with the cover off, loosen the 3 screws holding the printhead to make any adjustments needed to insure the print is straight.
Posted on Jun 20, 2008
  • 1602 Answers
SOURCE: printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Posted on Feb 03, 2009
  • 32 Answers
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Posted on Jul 24, 2009
  • 32 Answers
SOURCE: fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
IBM infoprint 1145 replaced fuser for line down page ( bad upper roller )now the printer has 2nd image on 2 half of the page we tured density down helped a little PS this our 3rd fuser
I think is the cartridge,if you say you change the fuser,try to change the cartrdge.The problem that you say in the main part is on the fuser,make sure the fixing film is ok,not spent.
Mar 14, 2011 | IBM Infoprint 1145 Laser Printer
We changed the fuser on the IBM Infoprint 40 Model #004, Type 4332. However, after changing the fuser, we still get an error code in the display that says "008 Change Fuser." What does code 008 mean? ...
008 is the printers code to tell you to replace the Maintenance Kit. IBM Part Number 90H3567. After installing it, you have to make sure to tell the printer to reset the count value for that maintenance kit.
Jun 11, 2010 | IBM Office Equipment & Supplies
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
IBM Infoprint 1532
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
IBM InfoPrint 1612 Repeatedly erroring - Paper Jam
Check the FUSER, I think your exit sensor is bad.
If you open the rear door, look inside where the paper starts to come out of the printer, you should see a small lever that triggers the PAPER EXIT sensor. It might be hard to see. If it is not broken, you need a new FUSER.
Mar 18, 2009 | IBM Infoprint 1612 Laser Printer
Hp laserjet 1320tn folds the upper right-hand corner of the page
Check carefully for any small scraps of paper caught in the paper path. Do a 1/2 way test, do a print job, listen for the paper to get just under the toner then quickly open the front of the printer (may take a few tries) see if the paper is folded there or if it's happening later that way. If it is folded before entering the fuser, you probably have a small piece of paper in the paper chute somewhere. If it's not and folds later, the fuser is probably worn badly.
Feb 09, 2009 | HP Laser Jet 1320 Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
IBM Infoprint 1585n Laser Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
