Question about Garden
Tried charging john deere battery no good after 4hrs.whats up
John deere riding mower, 200 series, charged battery overnight at first, battery charger reads only at 2 amps, tried different chargers, battery will not hold a charge. Battery worked fine the day before, had been using riding lawn mower daily or every other day for a few weeks
    Problem Solver:
  • 10 Answers
Walt
Does this mower have a Briggs and Stratton engine with overhead valves? If so, (and this will sound really weird) you need to adjust the valves. After a few hours of running, the intake valve will go out of adjustment so the decompressor won't work. It acts like the battery is dead when this occurs.
Posted on Mar 25, 2014
  • 57 Answers
SOURCE: 1 year old craftsman model 917-376742 battery not taking a charge
sounds like it didnt take a charge; make sure all electrical connections are good and that it is getting power to the built-in charger. is there a indicator showing that its charging? are all the wires on the mower connected? you may need to get a new battery
Posted on Jun 12, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
  • 760 Answers
SOURCE: I just bought my PR625Y22RKP and it says to charge
If it starts don't worry about 24 hours. Mow the lawn then put it back on charge. If it doesn't start pull the cord.
Posted on Jul 23, 2010
Testimonial: "Thanks. That is exactly what I did; it made sense. "
  • 407 Answers
SOURCE: Though my Worx WG781 cordless
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
Posted on May 20, 2011
philwalker78
  • 605 Answers
SOURCE: What is the lowest voltage that will turn over a Toro Super Recycler walk behind mower? The 12VDC battery I have steadily loses charge after sitting idle for a week. Shouldn't it hold a 12V charg
Hi, there are several answers for your questions but the most relavant is replace the battery, regards Phil.
Posted on Jun 23, 2012
I rolled our john deere riding mower and now it won't start. Help
check that in the rollover a safety micro switch and wires was not damaged
( seat , brake , clutch , deck etc )
Oct 01, 2016 | John Deere L100 Series
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
My l130 will not power the cutter
Check batter power is high enough to operate the electro magnet. Charger may not work if battery is very low and yellow light stays on. Check battery water level. Charge with external charger.
Jul 16, 2014 | John Deere L100 Series
Battery not charging
Looks like the battery is wasted. I'd have it replace it. A new battery should keep charged for longer period of time.
Jun 19, 2012 | John Deere Garden
The charging system on a C425 John Deere riding lawn mower will not charge the battery.
It could be that the battery is not taking a charge. If you have an external battery charger, try taking it out and charging it.
You should also be able to take the battery into your local auto parts store and they can test it for you for free.
If the battery tests good then you probably need to replace the alternator.
Jun 08, 2011 | John Deere Garden
Mower will not start - seems as if the battery is dead (what to do).
How old is the Battery? Are all battery terminals clean and tight?
Charge the Battery for one hour and if the battery charger has a starting position , after one hour set the charger to starting postion and try starting the mower. Make sure the blades are not still engaged the mower will not start. Check key switch. I have had them go bad.
Check all safety devices to see if maybe one of them might not be making contact.
Good Luck,
John
Sep 28, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
