Question about Radio Communications
Does not connect to others
When i have the other radio next to it it does not connect with the other one
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Check: Frequency of both radios (Simplex)
Sub audible tone same on both radios (used to eliminate squelch noise)
Posted on Mar 25, 2014
Can not hear transmissions
Check the SWR on your antenna first.. Most times the insulating washer's are in the wrong spot or even missing.. make sure the center conductor is not touching ground with ohm meter. and that the shield is connected to the body ground for starters.. Next make sure all the CB knobs are in the correct position.
if its an older radio may be few other issues. bad mics can cause 40ch radios to not RX if theres broken wires or bad switches..
Nov 14, 2015 | Radio Communications
I have a 2012 Colorado pu with a factory radio and it stopped working I checked the fuse under the hood it is good where do I look next
Does your radio still have power, but no sound? If so, check the antennae connection in the radio, and or fender...any other controls not working?
Jun 17, 2015 | Chevrolet Colorado Cars & Trucks
How do i get the radio to work
Besides playing your favorite songs and custom playlists, you can also listen to your favorite DJs and talk shows on your iPod Nano by using it as a radio.
The iPod Radio Remote is a small and convenient accessory that lets you tune in to live radio when you're on the go, and also allows you to remotely control your iPod. Here is how you can easily setup Radio Remote on your iPod Nano and start using it as a radio.
  1. Connect the ipod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
  2. Once the Radio Remote is connected, select "Music" and then "Radio" on your iPod. The Radio Remote will automatically tune in to the first available station it finds. The iPod screen will show the radio station and any other available information or data.
  3. Press the center button on the iPod. Use your iPod click wheel to find other stations. Once you have found your favorite station, hold the "Center" button down until a triangle appears on the radio dialer on your iPod screen.
  4. Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
Good luck.
Apr 28, 2010 | Apple iPod nano
Radio
Connect the iPod Radio Remote to your iPod Nano by plugging it into the dock connector. Plug your headphones into the port at the top of the Radio Remote, next to the hold switch.
Step4 Once you have set up all of your favorite radio stations, use the "Next/Fast-Forward" or "Previous/Rewind" buttons to navigate between them.
Feb 11, 2010 | Apple iPod nano
Am having problem installing my hp laserjet6p printer
just check out the instructions its for both inkjet and laser printers. When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
To switch to a new printer that you haven't designated as the default printer in programs such as Word and Excel, you need to open the Print dialog box (choose File-->Print) and then select the printer name in the Name drop-down list box.
Feb 02, 2009 | HP LaserJet 6p Printer
I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program...
To install the printer do this:
Nov 23, 2008 | Office Equipment & Supplies
Usb connection on sirius stiletto 2 to pc
I had a sync problem with the Stiletto 2 (SL2) and was able to resolve it by the following procedure:
Click "Start"
Click "Run" > Type "devmgmt.msc"
Click "+" next to "Other Devices"
Note: You should see a question mark and exclamation point next to "Stiletto 2"
Right click on "Stilleto 2" (to see menu); then, left Click "Update Driver."
Follow the steps in the windows hardware update wizard.
Apr 07, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
I had the same problem with both red lights going on..............
dear dan,
in many cases from my experience is Even brand new things have away of not always working right or being built all correctly my two suggestions for u is to take the radio back which at this point of replying may be to late Other way of doing this is if u got a local cb repair shop take it there and have then look at it.
Apr 04, 2008 | Uniden Bearcat Pro PC78LTW 40-Channels...
Car sterio
hi first remove the ash tray, there are screws located behind it, remove the screws next remove the radio to do this place the right pins in the 4 holes around the radio faciaand slide the radio out. behind the radio there are 2 screws on an aggle, remove them. next you gently tug the unit out from the bottom being careful of the wires, all the connections have a locking device on them
any other problems give me a yell
Feb 09, 2008 | DVO Enterprises Cook'n Fix & Forget...
Radio Communications Logo
26 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
