Question about HP Pavilion ze5570us Notebook
How to take apart hp ze5570us to see what is wrong with the plug socket for the charger? I have taken all screws out but the computer does not seem to be coming apart easily.
  • HP Master
  • 32,281 Answers
First of all remove all your components ie. RAM, hard drive, battery, CD/DVD drive etc. Sometimes there are screws located in the area where these components are located that secures the top and bottom halves of the case.
I suggest that as you remove the screws from the bottom of the case you take a note where the came from as some of the screws are different lengths.
There may be s strip panel between the top of the keyboard and the LCD screen, remove this first, it will be clipped in place and held with screws from the bottom of the laptop.
Next the keyboard should removed and keyboard cable.
Look closely for screws hidden behind plastic stick on covers, you need to use a sharp thin blade to lift off these covers to reveal the screws behind the covers.
The top and bottom halves of the case is usually held in place with plactic clips, start at an opening and carefully pull apart until a clip releases and the work along that edge to release more clips. Continue along each edge until you separate the case.
The LCD screen is usually secured with screws on the back edge of the laptop and possible with screws near the edge of the motherboard. Take care to disconnect the video connector.
The motherboard needs to be removed from the bottom half of the case so you can access the power connector.
Take careful note where you remove each screw as you need to put them back in reverse order.
Best of luck, have fun.
Posted on Jun 21, 2009
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
When I plug my Garmin Nuvi 765T into my car charger, it does not charge. Has the cord gone bad? Can I charge my Garmin through my computer?
The fuse may have blown in the charger. THe fuse is in the plug that goes into the cigarette lighter socket. Unscrew the ring near the tip of the socket being careful not to lose the tip. The socket comes apart when you remove the ring. Replace the fuse and it should be ok.
You can charge the satnav from your computer but it will take around 8 hours, twice as long as the car charger. Just connect it to your computer and turn both on to charge it.
Jun 16, 2011 | Garmin GPS
My nuvi 760 has never charged from the car. Is there another way to charge it?
It can be charged from a computer. Connect it to your computer with the mini USB lead and it will charge. It takes about 8 hours compared to 4 hours with the car charger or with a mains charger.
If your car charger isn't working it's likely that the fuse is blown. I presume you checked the cigarette lighter socket first and that it's working. If not try something else in the socket and make sure that's not the problem.
At the end of the charger lead plug, that goes in the cigarette lighter socket, there's a ring. Unscrew the ring and the plug comes apart. Be careful not to lose the silver tip. When the plug comes apart you'll see the fuse. You'll get a replacement in any car electrics shop or anywhere that supplies satnavs. I hope this solves your problem.
Jan 08, 2011 | Garmin GPS
My nuvi 760 doesn't charge in the car. is there another way to charge it?
Jan 08, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
Broken socket for charger - Esprimo mobile V5515
you have to prise the keyboard out, then prise off the strip of plastic at the top. It's not a nice thing to have to do...
I had the same problem with the charger socket :(
Mar 29, 2009 | Fujitsu Siemens Computers & Internet
Compaq wont Boot
Apart that replacing the motherboard on a laptop is a difficult and expensive operation, component inside must be tested, as the problem is not necessarily the motherboard.
Try first starting the laptop without the battery, and only power adapter.
If it still does not start, and the AC charger has the right voltage (the one written +- .5 on reading) the laptop must be taken apart and tested.
The most likely is that the AC socket on motherboard had shorted or another component near the socket had blown because of the original accident.
Jan 05, 2009 | HP Compaq Presario C304NR Notebook
My Packard Bell easynote laptop does not charge up. The Battery is OK and the charger is OK
Sounds like your power plug has come desoldered. This is internal and will have to be taken apart to repair. If you are comfortable with taking it apart you can repair it yourself. If you have not ever soldered anything before or taken a laptop apart before you need to have someone else do it.
If you decide to do it yourself you will need the instruction manual to locate all of the screws. You will need a soldering iron and a camera along with a pencil and paper to draw a diagram and take notes. Laptops have a lot of fragile parts in them that will break. Do not do this if you do not know how. This is something that a qualified tech should do. You will see the plug and you will need to re-solder it back onto the board. One wrong move and you could damage the entire computer. If you try to do this yourself you are on your own and I am not responsible nor is anyone else.
May 30, 2008 | Computers & Internet
HP Pavilion ze5570us Notebook Logo
254 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
