Question about Frigidaire ATF6000ES Front Load Washer
Cycle timer will not change cycles
  • Official Brand Answer
  • 2,267 Answers
Hey Dina, this is JK. I see that your washer (ATF6000ES) is not advancing through cycles. There are a few things that could be causing concerns, the timer and the door latch. The timer could be considered the brain that controls the system. The timer's motor can also become defective, thus preventing the timer from advancing through its cycles. If these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Best Regards,
Posted on Mar 25, 2014
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
Oct 01, 2011 | Hardware & Accessories
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
Without doing the minimal setting test to see if a time clock works how do you test a time clock with defrost termination the x terminal
8145-20 is 240Volt defrost timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
You are testing the 8145-20 timer.
The timer dial should rotate continuously. Trippers on dial rotate around. When they reach the trip switch, the timer starts the defrost cycle.
Terminal 3 has power during defrost cycle.
Terminal 4 has no power during defrost cycle.
With 240Volt timer, terminals 1 and 2 and N and X test for live power to ground at all times.
The limit switch is connected to terminal X and to terminal N.
During the defrost cycle, the limit switch measures the pressure or temperature.
When pressure or temperature reaches the set point, the limit switch closes the circuit and this trips the solenoid inside timer. The solenoid turns off the timer relay, and the defrost cycle ends.
At this point the timer turns off the defrost, and sends power to the refrigeration.
Terminal 3 has no power during refrigeration cycle. (The opposite of defrost cycle).
Terminal 4 has power during refrigeration cycle.
Test these terminals for power to ground. One or the other should have power at all times, but not both.
If timer will not enter defrost cycle, make sure the X-3596 trippers are not worn down.
Disconnect the wire to terminal X and see if defrost cycle will start.
Test terminals 3 and 4 again and see if removing wire from X caused a change.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Paragon 8145-20 Defrost Timer
My whirlpool gold quiet partner II will not change cycles it just keeps running. What can I do?
Hello there and thank you for choosing fixya
This is a fairly common issue with these dishwashers the problem usualy stems from the timer itself the timer tells the machine to switch to the next cycle after a given amount of time and when it quits working then the timer needs to be replaced
So what you will want to do is first try a different load cycle or even try them all to see if it changes if so then this is a true sign of the timer being bad ok so if it does work in lets say a light cycle but not in the normal cycle this means that the normal cycle part of the timer is bad ok?
Please try these first and post back to to what you have discovered andi can continue to help you form there ok?
Best regards Mike
Aug 03, 2011 | Whirlpool DU1055XTSD 24 in. Dishwasher
My washer won't change cycles on it's own. I have to change it's cycle manually. What do you think is the problem?
well if your saying that when you select a cycle and start a load andtrhe washer timer isnt advancing to the end of cycle then you have a timer problem...... but if it stops before rinse and spin in every cycle i would say you have a bad lid switch...
Jan 24, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Timers are not advancing through cycle. Dryer just continues to run. Thank you for your assistance. Chuck
Hi Chuck,
If the dryer is heating up and the timer will not advance in either time or automatic cycles, you will need to change the timer. If the timer advances in time cycle but not the auto cycle, you need to make sure it is heating properly. The timer only advances in the auto cycle after it reaches a certain temperature.
I hope this helps you at all. Please let me know if I can assist you further in this matter.
Thanks
Vic
Feb 12, 2010 | Dryers
ELEC. DRYER WON'T START
You could change the timer...that sounds logical.
Sep 26, 2009 | Whirlpool Dryers
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Washer won't change cycles
yes check the lid switch timer
Jul 17, 2009 | Kenmore 22422 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
