Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a Model FEFB68CJSA Frigidaire range that has a constant F1 code that won't silence.
The clock and lock lights on the control board are lit and the clock won't program. The oven door lock constantly rotates when the door is closed, but stops when it is open. I have metered the micro switches on the lock shaft and they check out OK. Is the door lock relay in the control a hard-wire relay that could be frozen in the closed position that would keep rotating the lock motor? I wonder what conditions are necessary to satisfy the limits for the lock motor to stop. Could a bad temperature sensor or oven cleaning command lock up the control logic. I have tried numerous times to interrupt power for various lengths of time but the clock flashes for a few minutes then goes into the F1 mode that can't be silenced.
  • Frigidaire
    Frigidaire Mar 26, 2014
    Good Afternoon Gary, I see that you are having trouble with an F1 error code that keeps appearing on your display, after numerous attempts of giving your appliance, model# FEFB68CJSA, a hard reset. This F1 error code tells me one of two things. 1) The keypad could be shorted. In this instance you would replace the keypad. 2) The control has sensed a potential runaway oven condition. This can also be caused by a shorted relay. If this is the case you will want to replace the sensor probe itself. I do recommend having a local authorized technician to come out and diagnose the range completely. Hope that this has helped. Best Regards, WP
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Posted on Feb 23, 2009
localwonder
  • 6784 Answers
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Posted on Apr 16, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
    Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
    Posted on Nov 13, 2012
    What does E2 -F 1- mean?
    It helps to know make and model in such questions.
    Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
    https://www.shopyourway.com/questions/1183452
    Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
    25 Jun 2013
    Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
    17 Sep 2012
    What does error code F1 mean on my Whirlpool ...
    1 answer
    14 May 2010
    What does E2 F1 mean on a Kenmore electric range ...
    1 answer
    25 Mar 2009
    More results from www.shopyourway.com
    Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
    https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
    Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
    https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
    Whirlpool Appliance Fault Codes ' PartSelect.com
    https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
    Mar 24, 2018 | Whirlpool Ovens
    Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
    You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
    Usually the F1 feature does not go away unless you replace the electronic/control board.
    I wonder what would happen if you set the door lock assembly to where it was before?
    Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
    F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
    An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
    Dec 05, 2012 | Ovens
    Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
    I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
    May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    Have a Frigidaire FEF353bfwc. Getting error message F1 and start button lights up and beeps constantly. What to do? Can it be fixed? and what would you guess is approximate cost?
    Hello there and thank you for choosing fixya
    The dreaded F1 error code can be difficult to diagnose but here is the best thing to do
    this is from the manufacture of the oven.
    F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
    - Disconnect power to the range.
    - Gain access to the back of the ERC (electronic range control, or "clock").
    - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
    - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
    - Turn the power back on to the range.
    - Watch for the F-1 and listen for the beep.
    - If you get the F-1 and beep, replace the ERC.
    - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
    Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
    Aug 05, 2011 | Ovens
    My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
    This should help any further assistance please feel free to contact me.
    WHIRLPOOL
    Range/Stove/Oven Fault Codes Non Y-Line
    NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
    Failure
    Code
    Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
    2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
    Range/Stove Oven Fault Codes, Common
    Failure
    Code
    Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
    Jul 16, 2011 | Whirlpool Ovens
    F1 error code and constant beeping and oven shuts off.
    Hi gwhiz03,
    If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
    Hope this helps.
    Thank you for using FixYa.
    Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
    Our Fridigaire range oven will not shut off. In
    F1 is a bad oven control. (clock).
    It must be replaced.
    Unplug the range.
    Remove the screws from the rear panel.
    Remove the wires from the (clock).
    Replace the EOC (clock) with a new control and bake me some cookies.
    Feb 02, 2010 | Frigidaire Ovens
    My kenmore electronic stove is having a beep with code F1 on the
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Fault Code F1
    Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
    Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    Top Frigidaire Ovens Experts
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Starnley Johnwells
    Starnley Johnwells
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
