Question about Raymarine A78 7" Mfd Combo Wifi/chirp/downvision T/m Gold
How to set destinations on raymarine a 78
A50D
In general, you should be ablt to go to the settings page and one of the items will be units. Go to that page to change the units. Raymarine has an extensive on line set of usermanuals for more detail.
Jul 14, 2014 | Raymarine Boating
In Speedometer 6y5-83570-s6 there are two black wires which is ground and which goes to fuel tank?
My Raymarine E80 depth display kept freezing up (display then says "DSM connection lost"). Of course, this seems to happen more often when entering a tight shallow anchorage in Alaska's inside passage. Raymarine tech support recommended that I update the display software and then update the DSM300 sounder software. I did this to no avail. Then Raymarine told me to install a dashboard mounted toggle switch inline with the positive power input of the DSM300 module so I could do hard re-sets (turning off the system power or powering down the displays does not reset the sounder module). This I did. Now when entering a tight anchorage, the display still freezes, but at least I can do a hard re-set with the new toggle switch and have the unit back up in about 40 seconds (a life time in a tight channel with the current running, etc.). Now, Raymarine says that if I send in the DSM module to them, they will replace it with their new circuit boards that solve this chronic problem that they have known about for a long time (hello, this is a significant safety issue - why no recall?).
Don't mess with this - send your DSM300 in to Raymarine!
Bob S.
Aug 30, 2013 | Boating
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
I am having problems getting started. Thought i
Unfortunately the Raymarine A60 does not have the automatic route feature built into the unit. You would have to create a route if you were planning a long trip. A route is a collection of waypoints that are linked together. Each time you reach a waypoint the A60 will notify you of the arrival and move on to the next waypoint.
Jun 16, 2010 | Raymarine A60 Dual Function System Pack
I need a new power cable for a raymarine DS500X fishfinder. Where is a good place to buy?
Contact Raymarine or your nearest Raymarine dealer. Raymarine normally has those things on their website although it's a bit cryptic to find sometimes.
Jan 18, 2010 | Raymarine Ds500x Color Fishfinder: Ds500x...
How do i set the serial number # on a C120 Raymarine?
you do not set it, but to retrieve it from the menus, go to system menu, system diagnostics, software services, unit info. or it shows during start up sequence
Dec 28, 2009 | Raymarine E120 Multifunction GPS Receiver
E120 screen is dark. checked brightness and
I would send it off the raymarine for repair. It could be something in the voltage regulator or the cfls.
Dec 22, 2009 | Raymarine E120 GPS Receiver
Raymarine A-65 unable to find satalites
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
May 17, 2008 | Raymarine A65 Combo GPS...
Raymarine A78 7" Mfd Combo Wifi/chirp/downvision T/m Gold Logo
Top Raymarine Sport & Outdoor - Others Experts
Are you a Raymarine Sport and Outdoor - Other Expert? Answer questions, earn points and help others
