Question about Yamaha RX-V371 A/V Receiver
I need to set my Yamaha rx v371 back to the Dolby logic setting. How do I do this?
Dolby logic setting
SOURCE: cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Posted on May 13, 2009
SOURCE: We have a Yamaha rx-v365 AV receiver. In basic
i have the same problem. any answers? navychief872000@yahoo.com
Posted on Nov 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a PS3 hooked up via HDMI to my Yamaha
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Posted on Dec 27, 2009
  • 127 Answers
SOURCE: how can I reset all settings on my yamaha rx-v730
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Posted on Mar 02, 2010
  • 10 Answers
SOURCE: how do i reset a Yamaha RX-V465 back
sledge hammer
Posted on Apr 06, 2010
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
I have a Samsung smart tv and a yamaha RX-V592 there is no optical or hdmi on the reviever. I really would like to listen to my tv in surround sound. What can I do?
You need a new receiver, that unit will only do Dolby Pro Logic and all 5 speakers will play but you have to use the composite audio cables(The red and white cables for audio) to get the audio into your receiver and the yellow is video which you can run thru the Yamaha as well if you want any on screen adjustments that unit may have and refer to your owners manual http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35288
Net unit make sure it as least 5.1 and you can get Dolby Atmos on a few select models but whatever you get make sure you can pass you video signal thru with HDMI cables or component at the least, a couple of years ago I went from the Yamaha R-V1300 to their RX-A3020 and couldn't be happier, the new one which is the Yamaha RX-A3040 has Dolby Atmos but whatever you get and you are only running it at Dolby 5.1 at least each speaker will be discreet unlike in the Dolby Pro Logic mode you will be running, and 5.1 means 3 speakers in the front and 2 in the back or on the rear sides, so that is your 5 the .1 refers to the subwoofer because it get a one tenth of the signal the rest of the speakers can do so 6.1 means 3 in the front and 3 in the bab plus the .1 subwoofer. My system will do 11.2 but I will be just happy with 7.2 but until I move into a house I run it at 5.1. godd luck and feel free to hit me up with any questions...
Feb 10, 2015 | Yamaha Audio Players & Recorders
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Apr 02, 2012 | Audio Players & Recorders
When i play dvds through my rx-v1000 the pro logic light is always on. shouldnt it be decoding a digital signal when im playing a dvd?
Hello,there is a chance that dolby digital isnt turned on on the dvd players audio settings, make sure in the dvd menu its not set to pcm.
Feb 08, 2011 | Yamaha RX-V1000 Receiver
My receiver switched from dolby digital to pro logic, but I cannot seem to get it to switch back. It is connected through optical audio to a motorola qip7100 hd receiver. i know that the channels are...
Check the settings in the Motorola to make sure it's outputting Dolby Digital instead of PCM stereo.
Indicators on the receiver can tell you if you're receiving mutlichannel audio or not.
Aug 22, 2010 | Yamaha RX-V995 Receiver
Open Questions:
See all Yamaha RX-V371 A/V Receiver Questions
Yamaha RX-V371 A/V Receiver Logo
20 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
