Question about Exercise & Fitness
Rower br 3150 ohjekirja
Pull cord wont go back in.
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: BR-3150 ROWING MACHINE WIRING DIAGRAM
go to www.iconservice.com or www.fitness.manualsonline.com and download
God bless you
Posted on Sep 25, 2012
Broken cord
Where can i get a replacement cord belt for the air rower, its frayed and snapped?
Mar 31, 2014 | Fitness Quest Integrity 3000 Air Rower
My york fitness r201 air rower wont retract
Did you get this fixed? Mine just broke too.
Mar 03, 2014 | York Exercise & Fitness
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
I have problem with Carl Lewis RO84 magnetic rowing machine, cord goes slack
dEAR Sir:
Adjust the damper on the rowing machine. The damper controls the amount of drag you are experiencing as you pull. It is supposed to simulate the drag in the water. Most rowing machines have 10 levels. Between levels 3 and 5 will be your closest simulation to the water. Consider this for your exercise if you are training to be a rower.
ernesto cuadra
managua, nicaragua. c.a
Mar 10, 2012 | Exercise & Fitness
Grinder will not turn on
Maybe carbon brushes or motor.
Unplug.
Unscrew and pull back cover nearest cord.
Brushes should be touching rotor, the copper segments, and not too short. Smell for burnt offerings from the motor.
Some tools have thermal protection too.
See if there's a thermal fuse, which looks like a small shiny rod with a wire each end.
It could be inside sleeving.
On an electric motor, this is usually embedded in the stator, or field windings.**
This may have blown if grinder got too hot..
**Would need complete strip-down to inspect.
If motor is cooked, get wallet out.
Motor-parts/repair labor may cost more more than a new grinder.
Carbon brushes:
Take sample to store, with make/model of grinder.
Brushes fairly cheap.
Hope this helps,
Clive.
Oct 19, 2017 | Dewalt Small Angle Grinder 4 1/2"
My integrity air 3000 has a elastic like cord attached to the underside to the chain. The elastic cord is now unraveling. Where would I get it repaired? I live in Columbia, Missouri. Thanks, Patti O.
Call Fitness Qwest at 800 321-9236 for the part. They will need the serial number of the machine (on the back stand underneath. All of the parts are easy to replace. It is an easy machine to work on.
Jul 05, 2009 | Fitness Quest Integrity 3000 Air Rower
What kinds of boats are used for rowing?
The boats (or shells) are basically of two types and reflectthe two forms of rowing---sweep rowing and sculling. In sweep rowing each rower handles a single oar (about 12.5 ft or 3.9 m long) in sculling a rower uses two oars, or sculls, (each about 9.5 ft or 3 m long). The word shell is often used in reference to the boats used because the hull is only about 1/8" to 1/4" thick to make it as light as possible. These shells are also rather long and racing shells are as narrow as possible while recreational ones can be rather wide. Most shells today are made of composite materials such as carbon fiber, fiberglass, or kevlar. A few manufacturers still build wooden boats. Each rower has his back to the direction the shell is moving and power is generated using a blended sequence of the rower's legs, back and arms. The rower sits on a sliding seat with wheels on a track called the slide. Each oar is held in a U-shaped swivel (oarlock) mounted on a metal pin at the end of a rigger. The rigger is an assembly of tubes that is tightly bolted to the body of the shell.The exception to this are some european recreational boats called "inriggers" which have the oarlock attach directly on the gunwale. The subtypes of rowing shells are classified according to the number of rowers in the shell. Sweep Boats (each rower has one oar) These shells can have a coxswain---a person who steers the shell (using a rudder) and urges the rowers on. I have included in parenthesis the symbol used for each subtype along with some dimensions and weights. Coxed Pair (2+) Two sweep rowers with a coxswain. Coxless Pair (2-) Two sweep rowers without a coxswain. Coxed Four (4+) Four sweep rowers with a coxswain. Straight (or Coxless) Four (4-) Four sweep rowers without a coxswain. Steering is usually accomplished via a rudder that is attached to a cable that is connected to one of the rower's foot stretchers (this an adjustable bracket to which the rower's feet are secured). The coxless pair has a similar type of rudder setup. Eight (8+/8o) Eight sweep rowers with a coxswain. Eights are 60+ ft (~18.5 m) long and weigh about 250 pounds (~114 kg). Sculling Boats (each rower has two oars) Only in rare cases do these boats have a coxswain. Steering is generally accomplished by applying more power or pressure to the oar(s) on one side of the shell. The hands overlap (usually left over right in the US) during part of the rowing cycle, or are always left in front of right. Single (1X) One rower or sculler. Singles are about 26 ft (8 m) long and less than a foot (0.3 m) wide. Racing singles can weigh as little as 30 pounds (~13.5 kg). There are heavier (~45 to 50 pounds), shorter and wider versions often referred to as recreational singles. Double (2X) Two scullers. Most racing doubles can be also used as a pair with a different set of riggers designed for sweep oars. When used as a pair a rudder is usually added. There are also recreational versions of sculling doubles. Quadruple (4X) Four scullers. Often referred to as a `quad' and usually has a rudder attached to one of the sculler's foot stretchers as in the straight four. Most quads can also be rigged as a straight four using a different set of riggers. Octuple (8X) Eight scullers. This is rarely seen, though is used in the UK, at least, in junior competition where sweep rowing is not allowed. Weight Classifications There are basically two weight classes for rowers---heavyweight (HWT) and lightweight (LWT). Men (M) For team LWT boats, there is a 72.5 kg (~160 lbs) individual maximum, and the boat must average no more than 70 kg (~155 lbs). Women (W) The individual maximum for team LWT boats is 59 kg (~130 lbs), and the boat must average no more than 57 kg (~125 lbs). In the US, the women have an individual max only; no average. In some regattas in the US (usually head races late in the season) these limits are increased by 5 lbs. A rowing shell is usually built with a particular weight class of rower in mind. Until just recently the Olympics effectively had only HWT classifications.
Dec 01, 2008 | Sevylor Fish Ranger 280
Oven elements not working but rest of oven does
try reseting your breakers may be partially triped if that dont work turn off breaker pull range out and chek the rower cord where it connects to the range if its burned on oneside replace cord and terminal block can get at lowes oven is fine just means cord wasnt tifhtned good when installed
Sep 23, 2007 | KitchenAid Architect Series KEBC107KSS...
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
