Question about Schwinn Cycling
Repair gears I was given a 1978 Schwinn Traveler that had been sitting out in the weather for a long time and was in bad shape. I found and installed a Shimano 105 triple crank bottom bracket assembly that fit perfectly, and also installed a 14-34 seven gear freewheel. My bike shop helped me replace the wheels) with aluminum wheels), the cables, and the brake pads. It has a very solid and smooth ride on flat roads, but on grades greater than +/-8% the lower gearing pulls the rear axle forward right out of the frame. Is there any way to restrain the axle and keep it from pulling out?
  • 4,521 Answers
Du u hav a park tool shop manual-or veiw their videos
Posted on Mar 24, 2014
  • 37 Answers
SOURCE: fine adustment - shimano sora triple flight deck
Go to Parktool.com
Posted on May 22, 2009
  • 484 Answers
SOURCE: shimano 105 flight deck diagram?
If this is not the diagram you are looking for, please check techdocs.shimano.com for the proper one.
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/CycleComputer/SI-0045A-001_v1_m56577569830684407.pdf
Posted on Nov 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi, Just bought a new bike with shimano tiagra
You don't mention which shifter(s) malfunction or if you're even pedaling the bike while shifting (I make NO assumptions).
If you operate the inner shift lever (NOT the brake lever) on each side through several clicks that should RELAX any tension in the shifter cables. Then if you pick the bike up and pedal it forward a couple of turns the front shifter should drop the chain the the lowest chainring and the rear derailleur should shift out the the smallest cog.
With the bike suspended (say, hanging from a low tree branch by the tip of the seat) you should be able to turn the cranks and manually pull sideways on either exposed shifter cable where it runs down along the downtube then release it.
This should cycle each respective derailleur through its entire range. If the cables don't travel sufficiently in this manner, the shifters will never make them do it either.
Perhaps you could CALL the Bike Shop and they would talk you through a quick operational check.
Posted on Apr 27, 2010
agent91
  • 2100 Answers
SOURCE: how to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
Posted on May 03, 2010
  • 1788 Answers
SOURCE: I have an older schwinn airdyne with the
I would take it in for service and let the professionals give it a tune up. You have a very good machine and I am sure that it needs to have the bottom bracket tightened and lubed. We have sold over 5000 Schwinn Air Dynes since 1981 and they are always worth fixing. So give it some love and it will be with you forever. Doctors and sports teams love these machines because it has a measured workload and they can write a program for you. We sell lots of excercise machines, treadmills etc but the Schwinn Air Dyne is the best of all of them.
Posted on Dec 30, 2010
Schwinn bike serial number 3240/vintage.what is it worth
Value varies greatly depending on physical and mechanical condition, and the Traveler is not a terribly collectible bike. Also, that is not a valid serial number, but rather a date code, translating to the 324th day of 1980 as the date of manufacture.
For more info: How to determine the year value etc of your bicycle
Sep 02, 2016 | Schwinn Cycling
Tip
Get Weather Difference, Currency and Exchange Rate On Symbian Mobiles While...
All those business travelers who keep on hopping and popping from one part of the globe to another on official tours, must have always needed some of the basic informations like the whether difference, currency exchange rate, time gap, etc between the place they are at currently and the place they will be visiting. To help those busy souls with these crucial figures, is the task of a freeware Symbian app World Traveler v1.05.
World Traveler is a breakthrough open platform application developed by Psiloc that is aimed to make a business traveler’s life easier. The currently released version offers four basic features:
  • Weather – a five day weather forecast and current conditions for around 2200 most popular travel locations worldwide.
  • World Clock – four analog or digital clocks which show local time at four cities of your choice simultaneously.
  • Currencies – automatic currency converter which uses local exchange rates. The currencies plug-in supports daily closing values of 184 exchange rates.
  • World Map – a moving 3D globe which shows day and night zones, My City and any city selected by the user.
on Mar 03, 2010 | Cell Phones
Schwinn gear selector wont turn
If the derailleurs move by hand OK and the shifters don't then you might consider the cable that connects the two - probably rusted out.
Jun 27, 2016 | Schwinn Cycling
I have a Schwinn bicycle with serial number FP571028 what can you tell me about it? Do you have a picture of one?
Schwinn Bicycle Production Codes
According to this gentleman's chart, the bike was produced in Chicago during June of 1978. I suspect you would have to contact Schwinn Chicago in order to find information on the bicycle with that exact serial number. Good luck!
Apr 30, 2012 | Cycling
How do I switch gears on the Schwinn Roxi Beach Crusier. I just bought it used and dont know how to swith gears?
Search engine "how to shift gears": or find the generic bike manual for Schwinns which can be found by searching for "schwinn bicycle manual". See how that works?.
Aug 17, 2011 | Cycling
I have a Schwinn Sidewinder 26" when it came into my possesion the right side gear controls where twisted well past and locked up, making it impossable for my to change the back tire gears, I've...
The detent mechanism is probably damaged. I'd get the whole shifter replaced and while you're at the REAL Bike Shop get the rest of the bike checked out.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Search the web for "how to...." any adjustment or operation question you have before coming here because many people online create helpful content that would provide instant answers and videos, while we volunteers may or may not a) see your question or b) decide to answer it.
Jul 30, 2011 | Schwinn Cycling
Where canI a manual for a Schwinn Chicago Traveler
Since their is very little difference between bikes of the same style (i.e. mountain/downhill/road/cruiser/etc) aside from the individual components (which can be adjusted or repaired with help from technical information from the manufacturer's websites), i recommend you use the resources of Park Tool's website. Parktool.com has a very helpful repair help section (find the link at the top-right of the home page) that is replete with repair, maintenance and adjustment information. It is loaded with images, too, to make it easier if the instructions are not as clear as you would like (but they are very easily understood, generally). Just select the area of the bike you are having trouble with and a list of topics will be brought up. Browse around and find all the information they have for your benefit.
i hope this helps you out
matthew
Nov 04, 2009 | Cycling
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
1978 Electra-Glide Starter initionally catches,
sounds like the starter is bad. if access to it easy for you then it can be removed and taken to your local repair shop and rebuilt. Or try locateing one on ebay.
Mar 11, 2009 | 2000 Harley Davidson FLHT Electra Glide...
Cycling Logo
82 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
