Question about Hoover AH60015 Air Purifier Replacement HEPA Filter with Charcoal,
Constant red light
Screen light is constantly red even after 3 hrs run. Fitted brand new filter , but still light is red . What would be the problem?
  • Hoover Master
  • 3,438 Answers
It may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Posted on Apr 03, 2014
Red filter light does not change to green when filter is changed
Call the manufacture and tell them it is defective and to please replace it.
Apr 02, 2014 | Holmes Products Air Purifiers
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
Mother gave me her filterqueen defender.. no manual. 360. There is a flashing red light even though its a new filter. Why?
The light is a reminder to change the filter, it does not sense if the filter has been changed or not.
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 28, 2010 | Filter Queen Defender Air Purifier
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
Nov 24, 2009 | Air Purifiers
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red light on air filter
    After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
    Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
    Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
    Red Light on front of Filter Queen Defender
    When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
    Mar 06, 2007 | Filter Queen Defender Air Purifier
    Hoover AH60015 Air Purifier Replacement HEPA Filter with Charcoal, Logo
    673 people viewed this question
    Top Hoover Air Purifiers Experts
    Thatvacguy.com
    Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
