Question about Toshiba Computers & Internet
I have a hitachi hdd 5k500 b-320 and my laptop doesn't recognize it....what can i do? thanks
I didn't drop the laptop but i installed win7 home premium 64bit again and when the computer asked to define the hard disk to install the windows i erased my hard drive and after the install me laptop doesn't see the disk at all
  • Toshiba Master
  • 3,320 Answers
Go to Disk management.
Partition and format the drive
Posted on Mar 28, 2014
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
  • 29 Answers
SOURCE: Hitachi HDD unlock
as far as i knew,the HD Doctor from salvationdata can help you with the password,their website is:http://www.salvationdata.com
Posted on Apr 14, 2009
fire sine
  • 382 Answers
SOURCE: Unable to install IOMEGA HDD on Vista Home Premium
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
Posted on Oct 22, 2007
  • 6 Answers
SOURCE: maxtor 3200 usb hard drive with windows vista home premium
Hey guys I had the same problem... All the drivers for the device are inside the harddrive. Maxtor doesn't have any because you don't need any. What they've neglected to let any of us know is the power supply provided with the unit isn't powerful enough to run it. Replace the original power supply with another one and this will solve the problem. I replaced mine with an old laptops power supply, the fit was alittle tight but believe me it works.
Posted on Apr 25, 2009
dmbgo
  • 58 Answers
SOURCE: drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Posted on Jun 21, 2009
How to downgrade fron win8 to win7 ?
wipe HDD, you can do it using Hierens Boot CD (boot from this CD and wipe HDD), then insert Win 7 DVD and install it
Nov 13, 2012 | Computers & Internet
Toshiba MK6025GAS HDD (External) not recognized
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
http://www.ebay.com.au/itm/280406610810?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
$2.37 + $2.61 postage worldwide
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
$10.65 free postage
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Nov 29, 2011 | Toshiba (MK6025GAS) 60 GB Hard Drive
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
Installed 2T Hitachi drive with controller as secondary drive. Devices show both working correctly. But XP doesn't recognize it. How do I get XP to recognize it?
This problem can easily be fixed. It is caused by your HDD not being formatted. Go to Start> Right click on "my computer" and select manage from the box that pops up. In the window that pops up then, click on Storage > Disk management on the left hand side. Then right click on the drive you installed, and click format. You should probably format as NTFS.
Jun 17, 2011 | Hitachi Deskstar 5K3000 HDS5C3020ALA632...
I just bought a new lap with ST9250315 AS HDD and i can't install winXP on it. First setup crashed, but i changed the BIOS setup for IDE instead of AHCI. After that installation goes ok until i...
Sometimes, recent hardwares (laptop components) don't have its drivers for XP1 & 2. (It conflicts.)
Try with XP3. Otherwise, you have to reinstall win7 and run win XP virtually under win7.
May 26, 2011 | Seagate Momentus 5400.6 (ST9250315AS) 250...
MY HITACHI 1 TB HARD DRIVE IS NOT BEEN RECOGNIZED BY MY SONY LAPTOP. IT WAS WORKING WELL 2 WEEKS AGO , HOWEVER TODAY I UNPLUGGED THE HARD DRIVE DURIN TRANSFER SOME FILES. UNTIL THAT MY COMPUTER STOP...
hello, if the hdd is not being recognize by your Sony laptop, may be because the device is not responding any more, anyway this is still new you can have that Hitachi replace via the warranty, but your not suppose to tell them what happen cause that would fall for intentional damage. Just tell them it stop working. Thank you for using Fixya
Mar 06, 2011 | Hitachi 1 TB SATA Hard Drive
I am trying to replace my HD in my Acer aspire 5520 from 160GB (Hitachi of 5400 rpm and 8 MB) to 500GB (Hitachi of 7200 rpm and 16 MB). Acer sent the recovery cd. I used an enclosure hard drive to format...
first ..Im not sure I understood how you installed windows on the new Hdd..but I sow that you didn't do it in the laptop ..
the correct way is to see if the laptop is seeing the Hdd..and to install the windows directly on the hard disk installed into the laptop ...by using boot-able installation disk with the operation system ..Cause if you install it on another device ..or other way ..it will not recognize the devices present on the laptop ..and most likely to give you a blue screen ..and errors like the one you just got ..
Another thing ..you have to go to bios settings ..advanced st-up ..most likely ..and see the Hdd in there ..and on its settings to disable the AHCI function ..cause if you do not have a disk with sata drivers ..the laptop with the AHci function enabled will not see the hard disk ..and this is the error and what it means ...basically it didnt found the boot device ..cause of this function probably enabled in bios..It is not hard to disable ..just press F2 on start up ..and go to BIOS settings ..and look for the feature that allow you to see the Hdd and disk drive ..and set them u ..it is either the device .or the advanced settings..Im not remembering exactly ..its the second or the 3rd feature..and in there you will find a function named...AHCI...this have to be disabled in order that the laptop to see and function with the HDD ..otherwise it will say that the HDD is missing or the boot device is not present ..
Aug 29, 2010 | Acer Computers & Internet
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
External HDD
I have 2.5" HItachi 120GB and the same problem !!
Nov 16, 2007 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
