Question about Wine & Spirits
How do you keep the cream from curdeling
Mixing togeather
    Problem Solver:
  • 13 Answers
Maybe try a different type of water. The PH balance could be off.
If the brand of Coffee is highly acidic, that could also cause curdling.
Good Luck..
Posted on Jun 04, 2014
I need instruction manual for prolectric ice cream maker 1 ltr
fill cylinder with ice cream mix, layer ice and salt in the outer section and plug it in. Keep the ice/salt coming until mix freezes and thickens. You will know this is happening by the sound of the motor and when the unit stops turning it is done. Enjoy some for me.
Aug 25, 2013 | Ice Cream Makers
Pump loses prime causing ice cream to spit out.
If it is "spitting" you might want to check all the components from the mix container all the way up to the door where ice cream is dispensed. Check for leaking mix hoses as well as broken or clogged diaphragm (inside fitting in mix cabinet). Refer to the manual to find the diaphragm.
Aug 26, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
We are opening a fast food shop in Florida and need to know how many cones can you get out of one gallon of hard ice cream and one mix of soft serve ice cream. Do hot dogs sell better than hamburgers and...
Hi. A typical soda fountain-style ice cream scoop--a #8 food portioning scoop--holds 1/2 cup of ice cream. One gallon is equal to 16 cups, so there are 32 scoops of ice cream in a one-gallon container. Each scoop should weigh 4 ounces. A strong handed scooper can put an ice cream shop into bankruptcy so ALWAYS weigh each and every scoop.
With soft serve, one gallon of mix makes 36 - 4 ounce cones. Once again weighting the cones is key.
The hot dog vs hamburg ? depends totally on the sizes, the toppings and the type of roll used. Experiment there but start out with hot dogs to keep it simple. Regarding chips and fries, once again chips are simple with little waste, cold fries often go in the trash. Good luck. J.
Sep 23, 2010 | Computers & Internet
Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
THE MOTOR ONLY TURNS THE CANASTER AND NOT THE SPADE
the dasher/spade remains stationary while the motor spins the bucket. That is how the frozen mix is moved toward the center as it freezes. if it didn't do that your motor couldn't keep going for long enough to freeze the mix.
May 25, 2010 | Maximatic Elite 4 Quart Ice Cream Maker
What's the recipe for coffee ice cream
Ingredients:
  • 2/3 cup sweetened condensed milk
  • 2 tablespoons instant espresso powder
  • 2 tablespoons espresso liqueur
  • 1 1/4 cups heavy cream
    Put the condensed milk in a bowl and stir in the espresso powder and liqueur. In a separate bowl, whisk the cream until it reaches soft peaks. Fold the cream into the condensed milk mixture, then pour this gorgeous caffe latte-colored airy mixture into an airtight container and freeze for 6 hours or overnight. Serve straight from the freezer.
    This is the best procedure to make a coffee ice cream.
Sep 17, 2009 | Ice Cream Makers
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Jun 04, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Broken plastic small drive gear.
buy a new icecream maker parts are to get for them.good luck.
Dec 24, 2006 | Rival GC9151 1 Quart Ice Cream Maker
Wine & Spirits Logo
418 people viewed this question
Top Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
