Question about Olympus E-620 Digital Camera with 14-42mm and 40-150mm lenses
D2C01 error code
What is the meaning of the above error code
  • 36 Answers
It's a non-critical shutter release error. It's nothing to worry about, and can be cleared and ignored. It happens sometimes when the camera is powered off (or the battery runs down) when it's still trying to do something.
Posted on Mar 25, 2014
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
ERROR CODE E000202-0002
Clear me about error code 000202 and send me the solution
Dec 19, 2012 | Canon imageRUNNER 3030 Black and White...
Hydropool hot tub error code 5n will not start up
The 5N error code is actually an SN error code which means one of your sensors is bad.
Rod Kidman
www.uspartscenter.com
Dec 01, 2012 | Intex Automatic Salt Water System for ...
Windows Update error code 80070103
This windows update error code means you already have the latest drivers installed onto your computer and you don't really need to upgrade it.
To know more, follow this link: Windows Update error code 80070103
or you can also visit: Update error Code 80070103
Hope this helps, Mrityunjay.
Jun 16, 2012 | Computers & Internet
Error code 24
2,4 is one of 5 error codes and means:
2blink-then 4 blink---------vertical circuit problem
The set may have a loss of sweep or even Glycol may have leaked from the picture tube above it onto the board in that area.
Vertical circuit is on middle board at front right edge.
Jun 16, 2012 | Mitsubishi WS-55311 55" Rear Projection...
What does the error 88 code mean
88 is not an error code. This means filter only
Jun 17, 2011 | Intex Automatic Salt Water System for ...
What does the code s e and u e on the washing machine samsung wf8704rsw display panel.
I think you probably mean 5E. This means that there is a water drain error. To clear it, turn the POWER SW OFF and back ON.
The code UE means a load unbalance and must be manually rectified by separating the clothing. To clear the error code, use the procedure outlined above.
Apr 27, 2011 | Washing Machines
I get a error f13 when i turn on broiler
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx
Above are the codes and meanings.
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power does not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Dec 13, 2010 | Frigidaire Kitchen Ranges
I have the error code 5 on the Ariston washer dryer combo AWD 121 what does it mean
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
Jun 07, 2010 | Ariston Technologies AWD121WH
Error code OE. What does it mean? washer seems to be having a hard time draining the water
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Please check the above link for a detailed picture wise explanation for the error code.
May 17, 2010 | LG WM-1832C Front Load Washer
Olympus E-620 Digital Camera with 14-42mm and 40-150mm lenses Logo
41 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
