Question about Nintendo Wii Console
TV settings needed to connect Wii to Mitsubishi CS-27201
How do I get the Wii system to appear on our Mitzubishi TV screen? We own a 1995 Mitsubishi model CS-27201 TV. We've correctly connected the Wii through the Video and AV ports, but cannot find the TV setting to get the Wii to show on the screen. The input button will take us to the EXT blank screen, but nothing appears except the label ''EXT S-Video'' when the DVD is plugged in, or just ''EXT'' if we unplug the DVD. This is the only button we have to change input and its exactly how the Nintendo web site instucts us to get the signal. We've also tried connecting it through both the input and output ports for the Audio/Video (yellow, white and red connections). Any additional suggestions?
SOURCE: How to connect a Nintendo Wii Audio Video ED Component Cable ?
Generally the Red, Blue, and Green are video with the remaining red and white are audio left and right respectively.
Posted on Dec 28, 2008
DirtyDozenUK
  • 57 Answers
SOURCE: I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Posted on Feb 07, 2009
InCaseyWood
  • 108 Answers
SOURCE: i have me wii at a friends house and cannot
Yes, you can connect through a VCR or the DVD player.
Posted on Dec 26, 2009
SOURCE: Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Posted on Dec 30, 2009
  • 19 Answers
SOURCE: i have flat screen ( ELEMENT) AND I PULLED UP THE
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
resma20
Posted on Jan 08, 2010
My mitsubishi cs- 27201 tv screen has horizontal white static lines that go across it when i turn it on, and usually goes away on its own but some times it stays please help.
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken.....
Good luck.
Jun 21, 2011 | Televison & Video
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Can i connect a pc to a wii to view pc screens a my tv
Instructions things you'll need:
  • Wireless router
    • 1 Determine if your Internet connection is compatible with the Wii's online console features. If you are using a dial-up connection you will not be able to connect to the Internet through the Wii console. The best connectivity is with a cable, DSL or fiber-optic connection.
    • 2 Start up your Wii. Go to the main menu. Click on the Wii icon button on the bottom left side of the screen.
    • 3 Select the "Wii Settings" button with a wrench icon. Go to the "Wii System Settings" menu.
    • 4 Click on the arrow on the right side of the screen to scroll to page two of the settings. Click on the "Internet" tab.
    • 5 Select "Connection Settings" from the menu that appears. Your screen should show three connection slots all saying "none" next to them. Select "Connection 1."
    • 6 Choose "Wireless Connection" from the pop-up screen. A new screen will appear that reads "Search for an Access Point," "Nintendo Wi-Fi USB Connector," and "Manual Setup." The easiest way to set up the Wii online is to select "Search for an Access Point."
    • 7 Wait a moment for your Wii to find an access point. When the words "Choose the access point you want to connect to" appear on your screen, click "OK."
    • 8 Pick your access point. Choose the point that is listed with a green signal strength icon.
    • 9 Save the settings by clicking "OK." Your Wii console will perform a test. A window will pop up asking you to perform a Wii system update.
    • 10 Complete the system update. Read and agree to the "User Agreements." You should be able to view movies, TV shows, websites, news and games from your PC on your TV.
Apr 17, 2011 | Nintendo Wii Console
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
Jan 14, 2011 | Mitsubishi CS-27205 TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Mitsubishi TV Model CS-27201 has picture for about 20 seconds after turning on, then a black mask covers all but the edges of the screen - sound is still on. It just happened for reasons unknown. But has...
Your TV is set to one of the CC [closed captioning] modes, particularly Text 1-Text 4. Make sure you use your remote control to set cc to off. This black box will go away.
Jun 29, 2008 | Televison & Video
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
It got stuck when beginning a game
go to the shop and tell them ur problem and get a exchange
Sep 02, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
400 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
