Question about Sharp AR-M205 Copier
Paper bunches up while printing
The paper begins to print, gets hung up and 1/2 the page is printed but the other half is not and there is a lot of excess ink on the page.
  • dave popoff Mar 27, 2014
    out of which tray, if it is out of all of them it is the registration roller clutch, if it is out of one of the trays, it is the paper feed clutch or roller
    President:
  • Sharp Master
  • 1,447 Answers
DC blade not working.Please replace drum unit
Posted on Jun 16, 2014
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
jonb3838
  • 237 Answers
SOURCE: 2 sided option grayed out under Document Style
This option is grayed out because you do not have a duplexer inside the machine or its an office machine and they have it locked
Posted on Feb 17, 2009
tehnik_bdg
  • 91 Answers
SOURCE: print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
Posted on May 20, 2009
  • 5 Answers
SOURCE: sharp ar287 error code F2-00 what is the
Toner problem, most especially try to change destination of that toner being fixed on the machine
Posted on Jul 04, 2009
n25an
  • 622 Answers
SOURCE: When trying to print, get error message to load
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
Posted on Dec 09, 2009
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
HP 1160 e cuts off side of page. How do I fix this?
Printing or paper?.. If printing check 1. check with another cartridge 2. check half test page(half test page while printing half page stop printer remove cartridge & paper see the image created on cartridge drum or not ,if not clean the Laser scanner assm, check on paper proper image or not if not clean the transfer roller.(looked like sponge roller located just under the cartridge location). beyond this trouble shoot, advised to send it to service center..
Sep 13, 2011 | HP LaserJet 1160 Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
How to print picture using 10x15cm photo paper? usually the pictures printed only half
Hi
1) when you begin to print have you set the paper size to the size you require ?
2) If not when you press print a grey box appears to comfirm printing yes!
3) press properties top right of page
4) open tab basic
5) Alter paper size to correct size
6) Also check your paper setting on the programme you are using to print from,
7) Also that the orientation is correct "portrate or landscape"
grandpaben
Nov 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Canon pixma ip 8500 won't feed paper
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Oct 15, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Out of order printing..
You did not adjust the label sensor.(media sensor)
1- for labels with a noth move towards the notch
2-for labels with a space between them move towards middle.
look at page 28 (zoom 400%)
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Oct 16, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Sharp AR-M205 Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
