Question about Drills
Dewalt pump parts dpd3100 n001194
Need this part cheep
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
  • 2448 Answers
SOURCE: How do you check oil in pump on Dewalt DPD3100
There is a little window on the side of the pump to see the oil level but thats normaly the problem None of these companys make there owen pumps or engines i owen serveral power washers if you can tell me more about the problem Iwill likely know how to fix it see who made the pump and the engine and let me know pier_j
Posted on Nov 24, 2010
  • 250 Answers
SOURCE: I have a Dewalt DPD3100,
Take the hose off the gun and see if water comes out. If so the gun has to be taken apart and cleaned. Also where the water hose goes in to the machine there is a screen filter which you might have to clean if water is not comming out on the gun side. Use a screwdriver and pry it out carefully around the edges Clean the screen with a wire brush and put it back in and try it.
Posted on Mar 20, 2011
  • 252 Answers
SOURCE: cam shaft bearings are seized
hi there perrinex22x
here is web site for parts
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
from diagram looks like not listed as seperate part
may need to remove them and see if your local bearing/ belt store distributor in your area may be able to source them
from list pt number N001194 pump assy is 505 $
sorry
here is another web site that may help for needle roller brgs - give a try
http://www.locateballbearings.com/roller-bearing-suppliers.html
cheers hope it helps pauly46
Posted on Jun 08, 2011
  • 13 Answers
SOURCE: I have a dewalt dpd3100 pressure washer. Recently started melting the spark plug wire along with air filter housing. What is the cause?
Sounds like the sparkplug wire is bad, and has gotten worse, grounding out to the housing... The burn is caused when the spark jumps the air-gap to ground, or through a damaged wire to ground...
Posted on Jul 23, 2016
DPD 3100 gas pressure washer. No water going through pressure washer. Have taken screen completely out and still no water moving through
See this diagram:
http://www.mastertoolrepair.com/images/DPD3100_pump.jpg?osCsid=1f3m03ijp5lcht6569kran6rk2
Remove Items 122 (Un;loader) and 138 (Thermail relief). Clean them up as best you can with a nylon brush under some slow running water. Dis-assemble the unloader valve completly to clean (both ends). Then lubrcate them with White Grease and reinstall both parts AFTER placing White grease in the cavity the valves mount into. Very briefly... Test water flow with the engine not running Then start the unit with water off and let run 30 seconds. Turn off engine. Turn ON water supply and test water flow engine OFF. Note you will get a certain amount of white grease initially that passes through the unit. Start unit and rapidly actuate the trigger 1/2 second on 1/2 second off multiple times to force the unloader valve to cycle.
You can get parts here if either of the valves have completly failed:
http://www.mastertoolrepair.com/dewalt-dpd3100-n001194-pump-p-59405.html
The above steps should get your presure washer working properly again.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Dewalt DPD3100 Gas Pressure Washer
What type of oil do i put in the DPD3100?
In the Pump Dewalt recommends
DeWalt DP70 Pressure Washer Pump OilIn the engine Dewalt Recommends
SAE 10W-30 is recommended for general use
Jun 26, 2011 | Dewalt DPD3100 Gas Pressure Washer
Cam shaft bearings are seized in Dewalt DPD3100 presure washer. does anyone know where to purchase the roller bearings. can not find a part number, do not want to purchase new pump
sorry
Jun 07, 2011 | Dewalt DPD3100 Gas Pressure Washer
I have a Dewalt DPD3100, 2 yrs old, never had any problem, water supply hose is attached, water is going in but no water out?
Mar 20, 2011 | Dewalt DPD3100 Gas Pressure Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
How do you check oil in pump on Dewalt DPD3100 pressure washer
Nov 23, 2010 | Dewalt DPD3100 Gas Pressure Washer
How do I winterize the pump....how do I get anti-freeze into it
We don't recommend using anti-freeze, see attached link for the different options to winterize your pump
http://www.wmpcs.com/blog/?p=63
Oct 30, 2010 | Dewalt DPD3100 Gas Pressure Washer
Hi
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
Power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Apr 11, 2009 | Dewalt DPD3100 Gas Pressure Washer
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
