Question about Able Planet Ableplanet Clear Harmony Around The Ear Noise Cancelling Headphones
The left hand speaker has snapped off the head band on my ableplanet NC2000B. Also, the blacl plastic that hold the headband together above the right speaker is coming apart. Can I buy a replacement headband or will ableplanet fix it?
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
Can not remove the water filter it's stuck
These water filters are prone to getting stuck. Remove the filter snap cover by gently prying hte left and right sides out. You will need to use 2 hands and grasp the filter head with one hand, which the filter twists into and the filter with the other hand, twist firmly to the left or counter clockwise at least half a turn. Not holding the filter head will cause the head to snap out of its holder and just flop down. Pleazer Appliance...
Apr 08, 2014 | Jenn-Air Refrigerators
Broken headband
You can try to strip a little bit of the jacket off the wires and twist them together securely. Then use a little bit of electrical tape to wrap the bare wire. After, you can tape the head piece back together...... or you could buy some new headphones.
May 24, 2012 | AKG GHS1 Headset
Raven01@Hi, The left hand speaker has snapped off the head band on my bose qc2. Also, the blacl plastic that hold the headband together above the right speaker is coming apart. Can I buy a replacement...
No, Bose doesn't cover any damage done to products that is any fault of the buyer. You might be able to if you contact a Bose retailer and special order it through them. Just a note, it will cost you more for the new speaker due to it being a special order. Probably around the lines of 40-50% of the original sales price (which is outrageous). If I were in your shoes, I'd try to find the same unit on craigslist or Ebay.
Jun 18, 2011 | Bose QuietComfort 2 Consumer Headphones
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Left earpiece removed
It rather depends on what broke on it. Sometimes superglue will hold it, but in my experiance if it gets a lot of stress it will go again. Another solution, if it is plastic that has snapped, is to melt them together with heat from a soldering iron. If you do this wear a mask and do it in a well vented area. You might need safety glasses as the smoke can make your eyes sore and also seems to go there.
One further way is to remove the speakers, find the size of them, then buy a cheap pair of headphones that uses the same size speakers as yours. Fit yours in. Afterall it's the speakers that output the great sound not the case!
Nov 16, 2009 | Grado SR80 Professional Headphones
Headband has broken on the 465 headphones. Is there an easy way to repair this\/
If it is plastic the only way I have found that will hold it together is to melt them together with a soldering Iron. I have tried glues, but they won't take the stress.
If you do try to melt them, use a face mask, safety glasses and do it in a well ventillated room. The smoke tends to go right in your face, it will make your eyes sore. So becarefull!
A much safer way is to find a cheap pair of headphones that will take the size of the speakers from yours, then fit them in. They might not look right, but they will sound the same!
That's what I did with mine!
Oct 26, 2009 | Sennheiser HD 465 Headphones
My old KOSS TD/60 Stereophones have a broken cable right near the earphone entry point. How can I open the earphone to repair or replace the cable?
I figured that that the earphones were pretty old, so if my 'repair' didn't work I would just replace them with new ones. There is a groove filled with acoustic foam that runs right around each earcup that terminates at the cord's entry point. After removing the headband yoke by carefully popping it out of each earcup I simply gripped both sides of the earcup and applied outward pressure until the front and back halves separated. Fortunately they are held together by plastic clips that snap apart. Once I had located the fault in the cable and repaired it the earcup halves easily snapped back into place. I now have a functioning set of headphones again!
Apr 22, 2008 | Audio Players & Recorders
Able Planet Ableplanet Clear Harmony Around The Ear Noise Cancelling Headphones Logo
42 people viewed this question
Top Able Planet Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Able Planet Audio Player and Recorder Expert? Answer questions, earn points and help others
