Question about Rimage 2000I Computers & Internet
Printer won't work
The machine will burn CDs but won't print them, I get "error code 7702" when it fails to print.
    Sergeant:
  • 376 Answers
Try reinstalling the software responsible for printing cd's.
Posted on Jul 04, 2014
CODE F9-88
F9-88 is a printer board communication error, either printer board has failed or the memory chip is no longer working. try unplugging printer cable and rebooting machine, or unplugging machine for 10 seconds and powering up again to reset the code.
Mar 22, 2014 | Sharp AR-M317 Black and White Copier
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is...
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Sep 11, 2011 | Brother HL-2040 Laser Printer
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error code 902.48 - won't print
Power off the machine and power it back on. Print a simple test page to determine if the problem is system software related or a corrupted print job. If the error is related to the corrupted print job, then there is no issue with the printer. If the error is not related to a corrupted print job and is believed to be system software related, Please call Lexmark Technical Support.
May 24, 2011 | Lexmark X342n All-In-One Laser Printer
How to solve error 4900ff on hp 4015 printer
Thank you for contacting FixYa with your printer inquiry.
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
  1. Turn the Machine on.
  2. Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
  3. Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Oct 04, 2010 | HP LaserJet P4015N Printer
: I bought a Acer One Netbook model AO751H-1948.
to tell u the reality the recovery disks is of no use as per my openion.
as they cant reload the OS in case ur machine crashes....so just have a WinOS CD from which u can reload OS again in case there is any crash,
the recovery disks do work but they wont help you in case you need to reload the OS again.
So just buy a WinOS if ur machine came with preinstalled OS
this is my experience and personal openion, the rest of the decison is left to you.
Jan 20, 2010 | Acer Aspire 5520-5908 Notebook
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
I am getting a toc error while trying to burn cds
Reinstall CD burning software and check.Also try to burn the CD in safe mode to check.
Jul 04, 2009 | Computers & Internet
Dvr-k16d dvdrw can't burn cds
if u get this error in every cd try different brands of media if it remains the same then try different burning softwares if problem persists then pls try the cleaning procedure for lens as follows
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works
pls do rate me FIXYA for help or ask more help if u want
Mar 31, 2009 | Computers & Internet
Cdj 800 error 8301
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Jun 11, 2008 | Pioneer CDJ-800 Turntable
Computers & Internet Logo
113 people viewed this question
Top Rimage Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Mike Carew
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
