Question about Honeywell Heating & Cooling
My honeywell st9400c changing from auto to continuous
My ST9400C is set on "Auto" but it keeps changing to "continuous" for no reason I can work out
  • Honeywell Master
  • 9,783 Answers
How old are the batteries? You may want to replace them to see if it helps. If it doesn't then get a new thermostat. Nothing inside the AC/Heater will cause that.
Posted on Mar 29, 2014
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
Mine is a Honeywell st9400c also (same as "andyrobbens") and it also shows "INTERNAL" (not internal fault, just the word "INTERNAL") Switching power off is not resetting it,...
By the way the battery is a common CR2032 battery and can be swapped out in 2 minutes. Turn off the unit at the mains, 2 screws at the bottom, push in the plastic connectors and the battery can be slid out
Jan 15, 2011 | Honeywell Electronic Programmable...
Internal fault
My installer hadn't the foggiest, lots of posts on the internet about this, and no solutions, so here's one I just got to work. Turn off mains to unit. (Note display still shows "INTERNAL FAULT" - this tells us message is maintained by the internal battery.) So, take ST9400C off the mounting plate, and using a small flat blade screwdriver ease out the four clips holding the plastic housing, top/bottom/sides. Now you can see the circuit board, in the middle of which is the lithium cell - ease the copper clip off to take this cell out. Display still says "INTERNAL FAULT" so this tells us a capacitor is maintaining the memory. Noting the large capacitor (blue in my unit) bottom right of the circuit board, short out the wires going to it (by putting your small flat blade screwdriver across both wires). Display no longer shows fault message. Put lithium cell back in, put housing back together, remount unit on backplate, turn on mains supply and unit starts as from new out of the box. Reprogram. Sorted. (I could perhaps have left the capacitor to discharge naturally once the cell was out, but life is too short and I wanted my heating to work.) Hope this helps in the worst UK winter for ages.
Jan 28, 2010 | Honeywell Electronic Programmable...
How to wire in a honeywell 9400c timer clock 4 ch
One of these wires is contains permanent live, neutral and earth. The other wil be heating on and hot water on, the earth on this wire will probably not be used.
you will have to trace the wiring back or test it!! Be carefull!!
Dec 11, 2008 | Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
