Question about Frontgate Professional 38" Grill
Natural gas conversion kit
I have an FG38, model number L04APGA25979 I would like to convert to natural gas. Is there a conversion kit available? I can't find one anywhere.
How to change from natural gas to LP
Brian, You usually have to purchase a conversion kit for your make and model #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stove conversion natural gas to Lp
Range Conversion
How to Convert Natural Gas To Propane DoItYourself com
Converting LPG and Natural Gas Appliances
May 12, 2016 | Kitchen Ranges
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
I have a grill Frigidaire FD27LKEC 27 it is running with natural gas and I would like to convert it to propan. Is there a convertion kit or what do I need to change.
At one time, there was a conversion kit available to convert your model from Natural Gas to Propane Gas. Unfortunately, it is no longer available and has been removed from the retail market. This, usually happens, when a problem resulted from a conversion of one gas type to another.
May 23, 2011 | Frigidaire FD27LKEC (LP) Grill
Conversion kit to switch to natural gas on modelFG50069
The model you have (G50069) has been discontinued by Fiesta and replaced by model # FGF50069-584LP (they are very similar). Neither your model or the current model have a conversion kit available. You either purchase/purchased it as a Propane model or a Natural Gas model. Even the Owners Manual states that it can not and should not be converted from one fuel type to another. (See link below)
http://www.blueembergrills.com/manuals/FGF/SP1811-37_FGF50069_ENG-V6.pdf
Hope this helped answer your question.
Apr 25, 2011 | Fiesta Blue Ember Gas Grill
What is the product # for the conversion kit from nat gas to lp? who carries this item? Does the conversion kit come with a regulator?
Some Thermador ranges are not field convertable from natural gas to LP. The PRG364EDG falls in this category. If you have one that is not convertiable; you will need a different range.
The PG364GEBS is not a listed unit at Thermador; I've found it for sale at AJ Madison. Since that vendor doesn't list the conversion kit (and they sell ones for other Thermador ranges), I do not believe this is a field convertible unit.
Thermador has manuals and installation guides for many of their appliances here: http://www.thermador.com/trade/specifications-guides . Most Thermador ranges come with the installation guide, as well as the owner's guide, if you still have your documentation. Otherwise, try the Thermador site for the documentation (check if the company uses a different part number internally). If the conversion kit is available, the part number will be provided in the section on the Gas Requirements and Hookup. If it isn't, the installation guide will clearly state that fact.
Other models are convertible. The PRD304GHU uses the conversion unit: PALPKITHC. You will need to confirm your model since the number of orifices will depend on the number of burners and the low simmer feature. (The PRD304GHU is also a 4 burner with 2 of them extra-low simmer burners model.)
For units that are convertible, you can usually order the part through the same stores that sell the appliance. Alternatively, have your gas service installer order the parts. The installation guide for the conversion kit will be included in the kit. For most ranges that are field convertable, the regulator converts from natural gas to LP by rotating a cap in the regulator by 180 degrees. (Take out the part, turn it over so that LP shows and reinstall.)
I hope this helps and I wiish that I had better news for you.
Mar 03, 2011 | Thermador PG364GEBS Stainless Steel Gas...
Bosche cooktop nht 725 a uc 1999 need conversion kit to go from natural gas to propane, hate to toss a good stove top need model kit order numbers
I spoke with Bosch customer service who said there is no natural to LP gas conversion kit available for the NHT 725.
Oct 05, 2010 | Bosch 30 in.NGP746UC / NGP742UC Gas...
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your self....you need to get rid of the Propane regulator....you need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Frontgate Professional 38" Grill Logo
41 people viewed this question
Top Frontgate Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frontgate Grilling Expert? Answer questions, earn points and help others
