Question about Indesit Washing Machines
WIRING FOR INDESIT WIB101
REPLACED DRUM AND HAVE A WIRE THAT I DONT KNOW WHERE IT GOES
  • 75 Answers
Hi where on the appliance is the wire is it a connection block can you list a photo
Posted on Mar 24, 2014
Replaced door seal, now not spinning ?
A disconnect of the plug contacts they may be loosened a important lead wire to the programm clock by an extreme tube movement by replacing the machine if you have handled it yourself without help from others and you tilted or shifted the machine to the drum to can happens !!
That short lead wire is to control the tub /drum for to great motion by centrifuge to heavy or a broken mounting brackets of the washing tub.
Its a safety connection there are models with this short cable introduced from early 2000 bild
Jan 02, 2016 | Indesit Washing Machines
My indesit model no WIB101 fills up with water but won't do anything after that
Switch for water level or hose that level switch should be clean inside...
Apr 21, 2014 | Washing Machines
Indesit 1000 wib101 filling but programme not moving any further
once the machine has filled the next requirement is to heat to temperature on some programmes the machine will agitate on others it wont try a different programme to see if you get any motor action if you do it may be something as simple as a heater failed
Mar 04, 2014 | Washing Machines
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
My indesit WIB101 is jumping, noisily on a spin, the drum belt loos fine but the seal inside the fron door looks all stretched and loose, do I need a new rubbe seal? Please answer quickly I cant afford a...
Possibly the drum spring/s are unhooked in the top of the washer. or the suspensions are loose or worn at the bottom.
This would cause the seal to twist out of shape.
Make sure the washer is level as well, as this can cause it to jump about.
you should not need to replace the seal unless it is split or has a hole/s in it.
Hope this helps you.
Dec 16, 2009 | AEG Washing Machines
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
i bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
Sep 14, 2008 | Indesit Washing Machines
Indesit washer
if you mean the wires that go to the back of the drum from left to right= green circle=brown wire pushon tellow/green(earth) square =2 lite blues yellow circle=dark blue if this isnt what you needed please respecify and ill do my best to answer ,ian if you add to this post it will inform me for a faster reply
Nov 03, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
