Fan in bottom of stove- think the Bering went
How to replace new fan?
  • 969 Answers
Depends on what make / model you have. Make sure the oven is turned off at the meter box before you do anything. Remove the oven shelves and racks. The fan blade should have a nut on the end of it. It may be a left hand thread. (Undoes by turning nut to the right) Once the fan is undone, this should expose any mounting screws. Undo the screws and the fan motor should lift out. On some cookers, the fan will only come out from the back. This means you will have to slide out the oven and remove the back panel to access it. Remember.. make sure the power is OFF at the meter box before you do anything.
Posted on Mar 30, 2014
The fan the circulates the warm exhaust air out the front of the unit is making a lot of noise.
and this is really a Frigidaire stove? Or is it a fridge?
Stove, check the circulation fan, which is usually at the back surrounded by the element. You can check if the fan has slipped on the spindle, but they often need replacing as they work in such a hostile atmosphere.
Fridge. you can check the fan which is at the rear at the bottom. Again, the fan may have moved, but the problem there is often the fibre board shield around the fan. If it is the compressor itself, it is beyond economical repair, you need a new fridge.
With both fans, they are made of aluminium and a blade can snap off. That makes them run out of balance and are noisy.
Dec 26, 2015 | Frigidaire FPDS3085KF Stainless Steel Dual...
The fan wont start
If the fan is hooked up with a thermostatic connection, you need to ensure that the thermostat is located where it is registering the heat. If not, try looking in the bottom behind the bottom louvres and making sure that 1. the fan is plugged in and 2. that the fan control switch underneath is turned on. If all of this is fine, make sure the outlet where the fan plugs into has power. Otherwise you need to trace all of the connection wires to the fan and ensure they are all connected. Beyond that, you may need a new fan.
Feb 24, 2014 | Heatilator GFK4B Fan Kit for ND4236,...
Looking for GE Range Manual for GRCL3650ZWW-1
I have a Convention GE Free Standing stove. Model #GRCL3650ZWW-2. The convention fan just suddenly quit working with no un-usual noises before. Im thinking the fan motor went. I probably can figure out whether out if its getting power but if it is gone where would I get one and about what cost for a fan motor
Sep 13, 2010 | Ovens
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Combustion fan isn't running
Ther is a guy names Murphy that it resposible for that. Go back through the steps you used to change the auger motor and see if maybe there was a wire left out or if the combustion motor is also out. What caused the outage? If a voltage spike, it could have taken them both out. The only other thing I can think of is a main switch somewhere. Good luck...Lee
Nov 14, 2009 | Napoleon Auburn Pellet Stove Heater
Jenn Air stove wired backwards
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
May 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Whining noise when the engine is running. i think it could by the fan, but when i move my steering wheel the noise lessens
Hi is your mini fitted with power steering if so this sounds like the steering rack if this is the case then you may also find that your hydraulic fluid is dissipating from the reservoir. Or it could be the drive Bering on the steering pump. Either way there is no quick fix or cheap way out as a new rack would cost around £500 with a new drive Bering around £150. If however it is not fitted with power steering then sorry I don’t know. Hope this helps
Sep 27, 2008 | Mini Cooper Cars & Trucks
Fan blades or motor in Nucor over the stove hood
it is hard to get the fan off. but if you are carfull you can do it. but any large home improvment store can help with a new fan.
May 03, 2008 | Kitchen Ranges
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
