Question about Hydromatic Pump Hydromatic V-A1 Submersible Sump Pump 0.30 HP 115V 1PH
Pump continuosly runs after water is cleared out of basin
Pump will start up and run for a very long time, even after basin is empty.
  • 25 Answers
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Posted on Mar 28, 2014
Machine starts its cycle but stop part way through and does not empty water.
Sounds like you need to clear out the drain pump. if you should be able to access the pump from the front bottom by opening the small door or flap unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Hope this helps
Mar 23, 2011 | Washing Machines
The water basin that receives and pumps out the excess water on my Aprilaire 600 humidifier runs incessantly, even when very little waters in in teh basin? Is there an easy fix? thank you
If you are referring to a condensate pump then the float might be stuck and causing the pump to run continuously. The best thing to do is turn off power to the pump and clean it out and make sure the float is free and not stuck.
Jan 21, 2011 | Aprilaire 600 Humidifier
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Sump pump won't stop running
by the sounds of it, you are not in a very snowy climate in the northern hemisphere, or you are in a heat wave. the sump is used for getting rid of ground water near the footing of the walls so the soil doesn't become too loose (or wash away) and your house does not sink. right now, it sounds as if the sump pump is taking the water from the ground, pumping it back on your lawn, it soaks back into the ground in to the sump, and continues over and over. see where it's unloading. the outlet tubing should let out at least 10 feet from the house. if the hose is broken or fell off near the wall of your house, the expelled water is soaking back into the ground and right back into the sump. there may also be an underground water issue. if your water table is unusually high or there is a water main break, you'll have the same problem.
Jan 05, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Duet
yes it should run continuosly,(at least untill the water level drops.) a more common instance withthis machine is that the drain line is blocked/restricted, or somethingis ninthe pump housing. it is even possible hat the pump impeller has dislodged from the housing and although it sounds as if its "pumping" its moving no water..usually in htis case your able to open the filter assembly and "pushback on hte impeller(normal impeller will not ,ove back" however if it was dislodged it will have foward play.i would even blow out the drain hose form the pump to the drain standpipe, just in case.
F02 is def a long pump out time and no ther ewill be no high speed spin with water in unit(or if it thinks thers water in unit)
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hydromatic Pump Hydromatic V-A1 Submersible Sump Pump 0.30 HP 115V 1PH Logo
200 people viewed this question
Top Hydromatic Pump Plumbing Experts
Paul Carew
Tom Chichester
Are you a Hydromatic Pump Plumbing Expert? Answer questions, earn points and help others
