Alarm on boot (PC)
Have Intel P4 2.60 GHz with MSI SiS 661FX MOBO S/V/L and 1GB RAM. Have two hard drives, a CD R/W and DVD R/W, a ZIP and 3.54 floppy drive. Extra drives supported by a Promise ULTRA 133.
Been using PC for years without problem. Recently retired and moved from Houston to North Texas farm. Now when booting get 7 seconds of tone followed by 4 seconds of silence (repeats). Normal boot messages do not appear. O/S does not boot (W2K Pro).
Have checked connections, reseated daughter cards, currently clueless as to what the promise or solution might be.
Help greatly appreciated.
  • Keith Brown
    Keith Brown Jun 19, 2009
    Thank you for the info... Also received a similar answer from Great Britain on June 15/16. Much appreciated.
  • 244 Answers
The repeated tone and silent intervals is a way the motherboard has to communicate that there is a problem with a hardware component.
Every motherboard has its own "language" and the sequence of beeps and silent means different things among brands.
Look into the manual, to find out the meaning.
Sometimes a faulty memory module may induce a computer to act as you described.
To make a quick test, remove the memory and start the pc without it.
If the tone and silent are the same, then clean the memory slot from dust, reset the memory in place, and try again.
If still no behavior's change....then you should get a new memory module.
Good luck
Please rate this answer if its useful
Posted on Jun 18, 2009
PC Compaq Presario S5160UK boot problems
From the description you have given, I would suggest that you re-install the operating system(Windows) make sure you save any thing on the computer that you can't live without. (Music, photos and videos). You will need to do a format of the hard drive. As you may have an unknown piece of malware or just a badly corrupted operating system.
Jul 22, 2013 | Computers & Internet
I recently upgraded my ram (2 days back) to 1gb on my intel d915gav motherboard, first it seemed to work fine, but now the Pc won't boot, with it connected?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power an data leads make sure they have dust free secure connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 08, 2012 | Intel D915GAV Motherboard
CANT REINSTALL OPERATING SYSTEM
LOL, the ole netbooks, Not worth the money they cost in my opinion, specifically because of the problem you're having. There is no Optical Drive to reinstall the operating system.
You either have to run the Recovery Program which wipes out all your data, documents, music, pictures and videos or you will need an external DvD/CD drive to attach to the system and have a operating system disc to reinstall the operating system.
Apr 06, 2012 | MSI Wind U100-053US 10-Inch Mini Laptop...
Bios won't boot, fans work, drives are flashing but it won't boot, no beeps.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 09, 2010 | Intel Gigabyte GA-8S661FXM-775 SiS 661FX...
Alarm on boot (PC)
your computer is failing its POST (diagnostics). open the case and reseat all the cards and memory. make sure your CPU's cooling fan runs when you power up. recheck the disk drive cables and power connectors. good luck!
Jun 14, 2009 | Microsoft Windows 95 + Internet Explorer...
Computer shuts off
go to the bios then check, your processor deatials
Oct 24, 2008 | Computers & Internet
New laptop... HP Pavilion dv2000 DVD drive does not recognize any disk
i hope the size of file not larger then then the DVD/CD, ( i think you already know about that)
if you burn multiple format of file, make a folder and put all the file in the folder, so burn the folder,
especially when you put a zip folder, sometimes it will cause error,
Oct 23, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Driver
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Sep 17, 2008 | MSI 661FM3-V Motherboard
HP dv2000
stirred? I'd say it's lost in the murk...you'll need to boot from installation cd, and possibly reformat your drive. Hope you got backup...
Mar 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
90 people viewed this question
Alun Cox
David Payne
David Payne
