Question about GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven
How do I tighten a loose handle on a GE monogram wall oven
I need to tighten the handle
  • 116 Answers
SOURCE: TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Posted on Aug 31, 2008
  • 116 Answers
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
ginko
  • 19396 Answers
SOURCE: special GE wrench to remove front panel
You need a safety screwdriver or a safety wrench, you can find the tool at Stanley's, call them and tell them your appliance model number if you are not sure what tool to buy.
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: need instructions on my GE profile wall oven
GE.COM really helps
Posted on Sep 20, 2009
  • 189 Answers
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Posted on Mar 24, 2010
Open door handle is loose on a true temp GE stove how do I tighten the handle
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Jan 06, 2013 | Ovens
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
TOp Oven Light ..
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge monogram single convection wall oven
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven Logo
151 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
