Question about Brother MFC-7440N Multifunction Network Monochrome Laser Printer
Faint printing Printing is faint whether copying or printing, even on maximum contrast. this is all over the print, not in stripes. Toner is not low. No error message. Is this the fuser? if so, how do I replace it? Thanks
  • 38 Answers
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Posted on Mar 24, 2014
Soulvisitor
  • 1113 Answers
SOURCE: printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Posted on Nov 27, 2007
micromaster
  • 3614 Answers
SOURCE: Brother MFC 8500 print issue
mayy i know if this wide black streak that you called, was changing position or it always on the same spot always...
let me know
thank you
Posted on Jul 16, 2008
jtuminaro
  • 56 Answers
SOURCE: ghost printing
This machine needs a new fuser. That is a common issue.
Posted on Jan 15, 2009
SOURCE: Brother 5140 faint print
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, it COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Posted on Jan 20, 2009
SOURCE: Prints faint pages
I have the same problem. It appeared to happen only after I changed the drum but Brother says it's not the drum but could be the laser or something mechanical. It is totally random, sometimes it's fine for a week and other times it happens a few times a day.
It happens with printing and faxes. Not sure about copies.
Did you ever find a solution?
Posted on Jan 11, 2010
Lexmark 4039 laser printer is printing left side of the page faint
check the cartridge it has a toner pcr and cylinder inside maybe its defective or the ic chips
Feb 19, 2013 | Lexmark 4039P 4039 Plus Laser Printer...
In spite of changing the black toner cartridge and toner waste receptacle, the printing remains faint
If your printer prints with faint vertical stripes like this
slamfix_22.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Dec 28, 2010 | Samsung CLP 300 Laser Printer
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
Faint printing on samsung ml7140 laser printer -- even when cartridge is new
try adjust the toner aditiute by going in to the printer properties. adjust to 3 if posible and do a test print. If the print out is still faint. try update the firmware of your printer by going to www.samsung.com
May 15, 2010 | Samsung ML1740 Laser Printer
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
Printing too lightly
Is the paper hot when you take it off the printer? The reason I am asking is, there is a part called a fuser, its the last process in the printing cycle. The fuser gets to almost 300 degrees to melt the toner onto the paper. If the fuser is not working correctly then the paper will be room temp and their will be no print.
Apr 04, 2009 | Brother MFC 8220 All-In-One Laser Printer
OKI 4550 fax
try to boot the front cover and clean the glass over the lens
Dec 29, 2008 | OKIFAX 4500 Plain Paper LED Fax
Hp laser jet 2100 faint printing
Reinstall the printer driver again to check if driver has gone bad or not.
Dec 02, 2008 | HP LaserJet 2100 Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
My printer won't print multiple pages
The Toner is running low. What is happening is you are low on toner in the MIDDLE of the Cartiridge. Take the cartridge out and jently shake it left to right (be careful you dont make a mess) this will distribute the toner evenly. time to buy a spare as this wont last much longer.
Aug 28, 2007 | HP LaserJet 1100 Printer
Brother MFC-7440N Multifunction Network Monochrome Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
