Question about Garmin Edge 500 GPS Receiver
I can see my HR (bpm), but I cannot see my HR Max%.
Hi, I can see my HR (bpm), but I cannot see my HR Max%. Yesterday I made update to my Garmin Edge 500. I had in same page 1 box showing HR(bpm) and it is still showing my HR and in the next box I had my HR Max% and now it shows only HR Max _ _% I hope I wrote clearly that is working like bpm, but I can't see % How can I fix it...?
  • 279 Answers
SOURCE: Hi, Where can I find Mapsource software for garmin nuvi 500
Try going here. Hope this helps!!
http://www8.garmin.com/support/download_details.jsp?id=209
Posted on Sep 20, 2009
SOURCE: False Elevation Edge 705
I have exact same problem. It has been working for 5-6 months but suddenly on one trip it now reads app. 280 meters too high elavation
Posted on Feb 28, 2010
johnegan84
  • 73 Answers
SOURCE: false elevation reading with garmin edge 305
perform a software download from Garmin.com by logging onto the site and downloading the webupdater
Posted on Mar 27, 2010
SOURCE: Garmin Edge 305 completely dead
I found that switching the device on and/or off while connected to the computer can leave the screen blank, and won't give any sign of life when the ON/OFF button is pressed. In reality the device is on and the batteries will drain. Try a RESET in that case by pressing ON/OFF and MODE buttons, and briefly pressing the LAP button.
Posted on Aug 10, 2010
  • 81 Answers
SOURCE: I am charging the Garmin Edge 305 for 24 hrs or
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Posted on Sep 26, 2010
Adjust parameters garmin tour plus
step 1 ask a question.
step 2, use real english.
step 3, celebrate when real people can offer suggestions
Jul 27, 2014 | Garmin Cycling Computers: Edge Touring...
GPS elavation
The altimeter requires calibration on the Edge 800.
To calibrate the altimeter:
1. Select MENU > > System > GPS > Set Elevation.
2. Enter the elevation, and select the check box.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 13, 2011 | Garmin Edge 800 GPS-Enabled Cycling...
Hello, I own Garmin edge 705 I cannot turn it on when plugged to charger display shows battery icon close to empty (2 pixel line) and no charging is happening at all when connected to computer via...
Sounds like your battery has gone bad to me. I also own a garmin. I would suggest you contact garmin for repairs. You can go to their web site at www.garmin.com go to the top of the page where it says My garmin and log in to your account. If you don't have one then sign up for one its free. Then contact technical support either by email or by phone to get your unit repaired.
I hope this helps you out if it does please give me a YES on the web page you just received my response on. Thank you
Apr 13, 2011 | Garmin Edge 705 Handheld GPS Receiver
When I wear my hrm on he Garmin 301 and cycle, if I am mountain biking in very difficult terrain, my avg hr will be around 145 bpm for over an hour and the calorie count comes back as 130 cal? Impossible,...
This sounds like an OS issue, but may be a hardware failure. Do you ever notice your HRM disconnect and then reconnect to your GPS? If so you may be losing connection to your fitness device which could effect your results. If your connection is fine I would suggest giving the unit a firmware update using Garmins WebUpdater Software. Here is a link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Feb 25, 2011 | Garmin Forerunner 301
Garmin Nuvi 200 - continually updates firmware
I can help you fix your Garmin Nuvi 200W. You will find the newest version WebUpdater if you follow my links, released March 31, 2010. I think you will find between a Hard Reset and the new software, your Nuvi will be better than new again.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 22, 2010 | Garmin nuvi 200W GPS Receiver
Bpm isn't showed, i have changed the batery and bpm doesn't apear
I just helpped some one else with same probelm, try this see if it works.
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
Jan 17, 2010 | Garmin Forerunner 305 GPS Receiver
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
Garmin 305 edge
Re-register it, Re-update it at Garmin
Should be good
Hope this helps
Regards.
Aug 14, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 500 GPS Receiver Logo
15 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
