Question about Technics SL-BD20D Turntable
Turntable playing too slow
I've had this turntable for about six years. I've recently replaced both the belt and the stylus, but records still sound distorted. Specifically, tempos too slow, vocals too deep, etc. Can tell it's the speed as if I gently spin the record with my hand, everything sounds fine. Again, it's just a hair slow -- 33rpms seem to be playing at 30. This seems to be something of a common problem, but I have yet to see an actual fix anywhere. Further, there's no obvious way to open the case of the machine and get at the motor. Not that I'd know how to really fix it, anyway. Also, no pitch controls on the turntable. Any ideas? Should I just get a new turntable?
    New Friend:
  • 3 Answers
There is a (v.r) for speed in side look for it and turn it a little
Posted on Mar 24, 2014
fire sine
  • 382 Answers
SOURCE: Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Posted on Oct 28, 2007
djproaudio
  • 515 Answers
SOURCE: Pitch out of Tune
That is a strange issue. Not sure what could be causing this. Are you describing your issue correctly. Or do the records sound warped? If they sound warped, check to make sure that your voltage setting is set correctly for your area (115V or 220V). This is a switch located underneath your turntable platter. Just make sure you power off your unit before making the switch.
If this is not the issue, then I have no clue what you are talking about, as I've never hear about this on a 1200 turntable, and I work on them for a living.
Please be even more specific, or if you can, give us a call here @ the shop, and maybe play a record for us. Perhaps we can walk you through it over the phone. 1.877.357.7677 ext 1
- DJPROLAB
Posted on Feb 24, 2008
landsend
  • 1066 Answers
SOURCE: Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Posted on Mar 21, 2009
djtatty
  • 417 Answers
SOURCE: Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Posted on Aug 15, 2009
djproaudio
  • 515 Answers
SOURCE: I recently purchased a used Technics 1200-MK2
If you've determined it's not the pots, and you've already performed a thorough cleaning, there are only 2 other issues which would cause this...
1) Faulty Pitch Control Fader - might need to be replaced or cleaned. I would try cleaning first, by opening it up, and if that doesn't work, then replace. Replacing requires soldering. If your not comfortable desoldering/soldering, DO NOT DO THIS. The PCB for the pitch control is discontinued, and if damaged, you will be out of luck in trying to find a new one.
2) Main PCB Drive Circuits - there are 3 IC's which control the pitch/drive of this unit. IC101, IC201, IC301, if any of them are bad, you will have issues. Unfortunately, at this stage, I would suggest contacting a service tech for assistance.
- OPTiC
Master Technician, 1200s.com
Technics Parts : DJ Repair
Posted on Aug 28, 2009
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
How do I fix a turntable used for playing records from being slightly slow
Try replacing the drive belt. Look under the platter for a 'rubber band' that would connect the platter to a drive motor. I bet it's loose. My other idea is crazy, however, they do sell an item called a "variac" which has a knob to control the voltage to the player. It's big and bulky and not worth the trouble. I'm a musician so I have to have a player up to speed or slightly detune my guitar. Good luck..
Jan 13, 2015 | Audio Players & Recorders
Pitch is off--too slow before, now too fast.
The speed is set by a synchronous motor that drives the turn table. There may be a small adjustable resistor (pot) that will do the trick.
May 31, 2013 | Audio Technica AT-PL50 Turntable
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
PS-LX250H
Have you measured the stylus downforce. It usually is between 1 & 1.5 grams.
Apr 21, 2010 | Sony PS-LX250H Turntable
I have a Sony turntable. Never had a problem. I just started playing records on it recently and it has developed a screeching sound and the turntable slows. I removed the platter and check the belt and...
If it's a mechanical screech you should be able to recreate it by rotating the platter by hand clockwise. Are you saying that did not reveal anything? I'd suspect a foreign object is involved.
Mar 25, 2010 | Technics SL-BD22 Turntable
Turntable will slow down for a moment while playing causing a dragging effect in the sound of the record. Turntable hasn't been dropped or damaged in any way.
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Sep 28, 2009 | Stanton STR8-80 Turntable
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
Technics SL-BD20D Turntable Logo
413 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
