Question about SkyScan 86742 Digital Atomic Wall Clock
How do i display outside temp.
Outside temp. will not display
How do you get the outside temp to display?
sorry no idea what you have , so can not look for any help
Aug 29, 2015 | Audio Players & Recorders
Ultronic clock. weather station, where does it get the temp
There must be an outside sensor somewhere, usually a small white plastic box, some have a display, some don't.
Mar 09, 2015 | Washing Machines
How do you activate the outside temp display in a 2010 ford edge
Ford edge only has a compass not a outside temp display.
Jul 04, 2012 | 2005 Ford F-150
Overhead Outside Temp Display Not working
Check the wiring plug that goes into the back of the mirror. They come unplugged sometimes.
Jan 12, 2010 | 1999 Pontiac Montana
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
SkyScan 86742 Digital Atomic Wall Clock Logo
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
