Question about Vehicle Parts & Accessories
Broken gas caps
I have a broken locking gas cap on my truck, the entire top part have broken off,the bottom portion of the lock is still in the truck.now I cant get a grip to take it off now,What should I do?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Use pointy nose pliers, usually you can get into it and push the release or such to get it to move.
Posted on Mar 25, 2014
How to prevent vapor lock
vapors should be released by the evaporative control portion of the smog system , check the carcoal canister under the hood , theres a filter on the bottom . or the gas cap is not allowing fumes to escape
Jul 14, 2017 | Cars & Trucks
Removal of locking gas cap on 2005 cts cadillac
OK keep in mind child proof caps. Push down on gas cap and turn. If this doesn't work grab the outer rim of the cap tightly squeezing hard and turning. Now if this fails, you would have to pry off the top of the cap and then you will be able to remove the lower end of the cap with a pair of pliers or similar tool. GOOD LUCK FRIEND.
Sep 16, 2014 | 2005 Cadillac CTS 2.8
How do I open the petrol filler cap on a saxo desire car ?
Derek if its a non locking cap need to drill a hole in the side of cap insert screw 10 mm self tapping screw to lock the ratchet internaly the ratchet portion of cap is stripped an needs to be replaced
Jun 22, 2014 | 1998 Citroen Saxo 1.1
How to remove the locking gas cap with broken out tumbler
Use a BIG or screw driver or pry bar drive it threw where the lock cylinder is or was, and pry the top of the locking cap to get to the threaded part and then just unscrew it out of the tank that simple.
Apr 06, 2012 | 2007 Vento VThunder XL
I bought a gas cap from checker auto parts because mine was broken the new one does not click....is it not fitting correctly?
  • If you bought a new gas cap and it is not clicking it is either not a locking gas cap or it is to small and not catching properly. You might want to take that gas cap back and ask for the proper one.
Regards, Tony
May 10, 2011 | Ford Explorer Cars & Trucks
I tried to open the gas tank (lock) but i stick my key in (also tried the spare) but the lock would not turn. I looked up some toubleshooting and used wd40 in the lock and along the rubber seal outside but...
There is either a small piece of something keeping you from fully inserting the key , the lock is broken, or the lock has been replaced and the replacement uses a different key. On my 2009 Ex250 the key turns 1/4 turn clockwise and is very easy to turn. Worst case scenario, you may have to drill the tumblers out of the lock. Even if you undue all the top screws but the cap will not come off. There is one security screw under neath to keep the fuel thieves from just taking the top off. If you damage the cap beyond use you can always replace it with a Slingshotracing gas cap. You could take the tank to a locksmith to see if they can pick it. Hope this helps.
Mar 02, 2011 | 2008 kawasaki Ninja 250R
Replacing the low beam headlight on a 2004 gmc envoy
Just above the headlight assembly are two angled tabs, pull these straight up (they may need some effort). These will release the assembly, carefully pull the entire assembly forward. Access to the headlight bulb is behind the two rubber caps, the upper cap is for the low beam. Remove this cap, twist the headlight bulb socket CCW and remove. Disconnect bulb from harness by prying up gently on locking tab on socket, and pull bulb out. Being careful not to touch the new bulb glass surface with your finger, plug it into the socket and install it back into the headlight assembly turning it CW. Reinstall rubber cap, seat headlight assembly on frame, lining up the bottom and top pegs. Once the assembly is fully seated, push the two angled tabs down, locking the assembly in place.
Oct 15, 2009 | 2004 GMC Envoy
Gas cap v star 650
best bet would be to get a new one also remembering how much the dealers charge for there products i would go aftermarket threw partsunlimited, cruiser, or Tucker rocky but the dealer still has to order it for you, all have great quality products at cheaper prices than O.E.M replacements unless your still under warranty.
Jun 07, 2009 | 2003 Yamaha V Star 1100 Classic
Yamaha V-Star 1100 Gas Cap is Stuck
shoot wd40 into locking mech and press down hard on cap while turning key.....Tim
Jun 01, 2009 | 2003 Yamaha V Star 1100 Classic
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
