Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
NO PICTURE AT ALL
TV WAS WORKING FINE ALL DAY THEN ALL OF A SUDDEN NO PICTURE, BUT SOUND IS STILL WORKING FINE. NOT REALLY SURE WHAT TO DO, PLEASE HELP ME WITH ANY SOLUTIONS
  • Philips Master
  • 3,459 Answers
Common problem with this model. Its typicaly the HVG. You can get a repair kit from www.TvRepairKits.com
Posted on Jun 21, 2009
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
Need to fix Philiphs model 60p8341 ptv915
unplug the tv and remove the back cover,locate fuses and see if there bad.if so and you replaced a bad fuse and the unit works consider yourself lucky and invest in a surge protector if you dont already have one.if no fuses are bad you have a bad board most likley the power supply board.theres a risk of live voltage so be careful.
Aug 27, 2007 | Televison & Video
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Jan 27, 2009 | RCA 32V420T 32" TV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Phillips flat screen LCD will not turn back on?
Please the volume suddenly went out on my samsung s4223 42 inch screen i cant seeem to get any sound! Can u give me some clues as to what I can look at...I dont think the speaker blew and the picture is fine...
Please help
Aug 03, 2008 | Televison & Video
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
While watching tv, the tv all sudden goes snowy, no sound, and have to turn it off and back on to make it work again
Connect up another set right next to that set thats going out to make sure the cable or that line is not bad. It soukds as though you may have an intermittant tuner assembly inside the TV set. Its also a possablity that there could be a bad solder connectiuon in or around the tuner assembley. Not really a job for the user, as this set has hot and cold chassis, and can give a mean shock if you do not have the know how to work on these monsters. good Luck PS Please do not forget to rate this thread.
Dec 08, 2006 | RCA Scenium D40W20 40" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
