Question about Rockwell RK7866 Belt Disc Sander
How to replace the sanding belt
Please send instructions on how to change the sanding belt. Thank you.
  • 3 Answers
Google the model number and "manual".
Posted on Jun 25, 2014
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
LAT9116AAE transmission belt slipping, replaced belt & still the same problem. motor is loose so to adjust tension, so am wondering if trans. is pulling to hard, ??? do these fail & is it cost...
Hello, Thank You for using FixYa. I will be helping you today. Sometimes the pulley becomes glazed.. Use some sand paper and rough up the pulley on the motor and trans. Also make sure the belts on on the righ grove of the motor pulley.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Washing Machines
How do I change the dryer belt?
Hi
Please check the bellow links to get the instructions as to how to change belts:-
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
http://www.ehow.com/how_4841963_change-belt-maytag-dryer.html
http://www.applianceaid.com/maytag-dryers.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Maytag Dryers
I need a diagram to replace a serpentine belt on my amigo. I have spent 1 hour trying to find one on the internet. Can you please send me one. Thank you! Charla
Draw a picture of belt and pulleys,before you start. Then the one hour on the internet, could have been spent changing the belt
Have a repair shop, print you a copy, from All Data,Motor,Indentfix,etc data base
Sep 30, 2010 | Isuzu Amigo Cars & Trucks
My husband changed the sand in our Hayward Sand filter for our pool and now it leakes sand into the pool. What's wrong?
Thank you for posting your question here on Fixya.com.
He broke the lateral assembly in the process and it will need to be replaced. You'll need to know the model number of the filter to get one. Then remove the sand, replace the assembly, fill the tank ~1/2 way with water, slowly add the sand back into the tank and replace the valve.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 05, 2010 | Plumbing
Broken belt on Porter Cable 334 T2 palm sander
got it, go to Dewaltservicenet.com and download the instruction manual or look at it and on page 14 it gives a really great view of how to replace the belt. If I have helped you with your question would you please rate this response accordingly and thank you
Oct 12, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
How do you change belt on Bissell pro heat carpet cleaner. can you please send diagram or instruction how to change belts.
http://www.bissell.com/images/UserGuides/7950_1204.indd.pdf
here is the complete manual (it is in pdf form)includes diagrams & instructions on belt replacment.thanx for using fix-ya!!!please rate all replys.
Nov 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rockwell RK7866 Belt Disc Sander Logo
197 people viewed this question
Top Rockwell Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Rockwell Tool and Hardware - Other Expert? Answer questions, earn points and help others
