Question about Canon ImageClass MF6540 Copier
I have a cannon image class MF6540. When I try and print I get an error "out of paper". I have plently of paper. I am able to copy but not print.
Error "out of paper" but i have plenty of paper
  • 128 Answers
I assume you are trying to print from your computer.
The driver for this unit will give you an out of paper message almost any time it won't print for any reason.
If the unit copies, but does not print from your computer, then it is a communication issue. Perhaps uninstall/reinstall the driver?
Posted on Apr 03, 2014
biz_kid1
  • 107 Answers
SOURCE: Printer D880 Cannon System error E000. What will fdix it?
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Posted on Jan 06, 2009
Muggs01
  • 71 Answers
SOURCE: cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Posted on Jan 16, 2009
SOURCE: error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Posted on Feb 04, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
ermiaby
  • 54 Answers
SOURCE: System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Posted on Jan 17, 2010
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Sep 07, 2013 | Canon I-Sensys Mf4550d All-In-One Laser...
Tengo una image class mf 6540 marca error E000 NOSE COMO QUITARLO
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Sep 28, 2011 | Canon ImageClass MF6540 Copier
My Canon MF6540 is only pulling paper about 3/4 of way through when I am trying to scan/copy. There is no paper jam, and I have cleaned the machine. What could be wrong?
Does machine eports some eror like paper jam or similar o e001, ...
Check the paper sensor flapper on fixing unit, or clean all rollers with alcohol or water
Jan 29, 2010 | Canon ImageClass MF6540 Copier
I have a cannon image class D761. It wont make anymore copies. It says system error E000
That is a error code for the fixing unit... Did you try to unplug the copier for a few minutes? It may reset, if not you may have to have the fixing unit replaced...
Apr 19, 2009 | Office Equipment & Supplies
Error 002 with Canon image class MF 8180 C
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
Aug 19, 2008 | Office Equipment & Supplies
Canon ImageClass MF6540 Copier Logo
80 people viewed this question
old marine
old marine
