Question about Avanti Top Load Washer W797
Change the drain hose
The drain hose of Avanti W798is split broken in the middle... I would like to know how to remove the old broken drain hose to replace it with a new one
Message code F 21
Not sure what brand of washer you have. I know that the duet series has a drain filter that gets plugged occasionally. You open the drawer on the Good luck it's located above the drawer in the middle. Remove, rinse out the filter and reinstall. F21 means slow drain on many washers. It usually means, clogged filter, broken pump or impeller in the pump, or the drain hose is kinked or clogged. Good luck.
Jul 21, 2016 | Bosch Washing Machines
Tip
How to Change Thermostat in Avanti Studebaker car?
1) First buy a new thermostat for you car year and model.
2) Then as per the procedure. Remove the radiator cap. Be careful that there will be pressure in the radiator. So just let the pressure release first before removing the cap completely.
3) The thermostat is connected to the black hose coming from radiator.
4) On the top of the engine there will be thermostat cover. The cover is fitted by two bolts on each side.
5) Then remove the hose connected to radio with the help of a pier.
6) The other end of the hose is connected at thermostat cover. Carefully remove the other end of the hose. A bit of coolant will flow from the hose while removing the hose.
7) Remove the screws holding the thermostat cover. Lift the cover after the screws are takes out. Then take the thermostat seated under the cover.
8) Remove the old gasket out from the thermostat with the help of knife.
9) Before removing the old thermostat carefully notice the position of old thermostat. In the same way place the new thermostat with the spring assembly in the down side of the engine.
10) Refit all the parts removed while removing the old thermostat properly.
11)After every thing is fitted proper as it was before, then check the coolant level if its low get it refilled till the required level.
This will help. Thanks.
on Mar 19, 2010 | Avanti Studebaker Cars & Trucks
Washing machine flooded room
Wild guess, your supply hoses split, or the discharge hose split, or came out of the drain pipe, or not likely, the seal between transmission and tub has broken. Even more rare is the bottom of tub has rusted and failed, thus won't hold water anymore. How old is the machine? Maybe time to look for a gently used replacement machine.
Feb 27, 2015 | Whirlpool Washing Machines
I need to replace the drain hose on my Samsung dishwasher as old one split but cant work out how to do it.
It's a big job. You have to pull the dishwasher all the way out. On most Samsung DW's, you then need to remove the metal panel on the left side of the DW to be able to get to the case-brake assembly. Remove the water inlet port on the inside of the dishwahser by turning it counter-clockwise ( a tool will be required). Pull the case-break assembly out so you can get to the clamp that holds the drain hose in place. Pull the clamp down and remove the hose. Have a towel or Sham-Wow ready to catch all the water. You will have to disengage the hose clamp at the back of the dishwasher, then you can pull the hose out. Reverse the process to install the new hose. As I said, it's a big job; if it sounds like more than you want to do, I recommend calling a professional repairman. Sears has technicians who are experienced with Samsung dishwashers.
Aug 12, 2014 | Samsung Dishwashers
I WANT TO REPLACE DRAIN HOSE WITH NEW ONE AS OLD ONE SPLIT
It's a fairly big job. You have to pull the dishwasher out from under the cabinet. Then remove the left-hand metal panel. You should now be looking at the case-brake assembly. Reach inside the dishwahsher and turn the water-inlet bezel counter-clockwise to remove it. Now you can tilt out the case-brake assembly and loosen the clamp that holds the drain hose in place. Pull the hose off (have a towel or Sham-Wow ready to catch the water). Then you have to remove the clamp or hose-restraint at the back of the dishwasher. Thaen you can pull the drain hose out and replace it.
Avanti dishwasher won't drain
hi could be two things... 1 could be you have food or broken glass in pump..it wont spin if anything there... u need to unplug from mains ...undo filter and remove ..you may have a larg metal filter remove too... you now have access to pump sump area... empty all water left in there with cup... it might SMELL :) when pretty much empty run VERY GENTLY around bottom of pump well... could be broken glass so do it slowley ... remve aything in there .. you will find a hole at bottom put finger in and turn propeller pump see if its stuck.. it it turns .and nothing is in way.. put back together and test dishwasher on quick wash.. if still not emptying change pump..
mark 07779933829 ===== TURN OFF AND UNPLUG FIRST=====
Nov 23, 2011 | Avanti DW18 Built-in Dishwasher
My drain hose split and I don't know how to open machine to change it I add a pipe and 2 brackettes but its leaking so I need a new hose
There are 2 screws at the rear just under the lid, remove them and the lid will slide back a small amount and lift off.
Apr 18, 2010 | LG WM3431 Front Load Washer / Dryer
ADP 4502/5 not working,not draining water,start
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 13, 2009 | Dishwashers
My G E Power1 Dishwasher is holding in alot of water,I know a little is normal.There is a lot and the water it feels slimmy.Just 2 yrs old well takeen care of.HELP
Check the following areas for faults. This is an apparent drainage issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Jun 24, 2009 | GE Dishwashers
Draining problem
The magnet connects to the outside of the pump. Aftertime it will come loose from vibration and use. Just resecure it with electric tape or something. The hose that connects to the pump is held in place by a simple hose clamp. Also there's a propeller inside the pump that can get knock out of place. Which will also leave you with a tub full of water. Reposition it with a ink pen or small screwdriver. To access the water pump remove the back panel, its located at the bottom of the drum.
Nov 08, 2008 | Avanti Top Load Washer W797
Avanti Top Load Washer W797 Logo
26 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
