Question about Baumatic Ovens
I have a baumatic b151ss-b and it trips my RCD out everytime i select cooker or grill function, is this something to do with the switch? Is it an easy fix?
It started with tripping the RCD every now and then but it trips it every time I turn the oven on now
shanat
  • 359 Answers
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
Posted on May 26, 2008
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
  • 491 Answers
SOURCE: Last night the cooker rcd tripped. On resetting,
SOUNDS LIKE YOUR BOTTOM HEATING ELEMENT HAS BURNT OUT AND IS PROBLEY CAUSING A TRIP.
Posted on Oct 21, 2009
SOURCE: Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Posted on Nov 02, 2009
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
Oven. Tripped on switch board when baking
This sounds like the grill element has blown, usually when an element blows it will take out the circuit breakker or RCD at the consumer unit.
If you check around the grill element you will probably find a very small hole in the side of the element, this doesn't happen every time but most.
These are usually quite easy to change but remember to turn off the power before doing anything on the cooker.
You should be able to order the part off the internet, lots of companies supply these parts. You will need your model number and obviously your credit card.
If you don't feel confident, I am sure a local electrician will help you. I would advise that you don't use a company that specialises in appliance repairs as they will charge you a fee just to come out to see you.
Hope this helps
Jul 18, 2015 | Ovens
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
New (graded) smeg scp399x-8 no heat on any of the functions
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 07, 2013 | Smeg Ovens
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
Opening oven door trips rcd when up to temp. doesnt do it when cold
Nov 22, 2011 | Smeg SE290X Stainless Steel Electric...
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
Ovens Logo
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
