Question about Canon "infrared" Power Shot G6 7.1 Mp Digital Camera
When I turn on my Canon G6 power shot 7.1 megapixels it starts to work and then right when the camera turns on it turns off. I checked the batteries and they were fully charged. After the camera turns
My camera does not work correctly, every time I turn it on I turns right off, I have full batteries, and every time it turns off it says, "Lens".
  • Canon Master
  • 3,287 Answers
Hi Cayley,
Typically, when an electronic or electro-mechanical device - such as a computer or as in this case - your camera - is powered up; it goes through a "boot up" so to speak. Like your computer, the camera electronics performs some quick, basic checks on the electronic and mechanical systems during the boot up sequence. This often includes checking for the presence of a memory card, battery charge state, connection to a computer via USB cable - and - checking the lens position; and if it can be extended and reversed to a "home" position or not.
Because you're seeing a "lens" message, this is a clue that the camera boot up sequence has detected some sort of problem with the lens. Most often, the problem is tied to the lens not moving or not moving *fully* due to grit or sand lodged between 1) moving parts of the lens or 2) between moving parts of the lens and the stationary parts of the camera body itself. When you turn on the camera, does the lens move in and out - like it did before? If not, that is probably the cause. You can 1) send the camera to be repaired by Canon, 2) have a local repair shop attempt to fix it, 3) replace the camera with new - if it is older than a few years as it may not be worth the cost of investing $$ in old technology - or if this option is your plan, 4) attempt repair yourself. You have nothing to lose - you can try to help the lens extend by pulling while it s"boots" up if it is retracted - or pushing in on it if stuck in an extended position. That is the NORMAL test at boot - to extend then fully retract. You may get it to work, abd save the cost of repair or replacement - or you could damage the mechanism even more.
I hope this helps & good luck!
Posted on Mar 24, 2014
3 Suggested Answers
dll932
  • 40 Answers
SOURCE: Battery dies right away
You might want to try NON rechargeable batteries, particularly "digitally" rated alkalines. If this won't do it, I'd take it to get looked at.
Posted on Apr 29, 2007
  • 78 Answers
SOURCE: I have recently shot some pictures with my canon
It all depends on the environment you're shooting in. When shooting a wedding reception for instance inside in the evening I will generally use ISO 800 and I quite often use FE Lock which is very handy. FE Lock will pre-flash the speedlite and meter the result based on the center focus point in your viewfinder (it doesn't matter if you have set another focus point it will always meter to the center one so make sure that is over your subject when you use it). To use FE Lock press the button near your thumb that has the * symbol with the center focus point over the subject. You can then re-frame the shot if required and take the picture. The camera will take the picture based on that flash setting and you should find that the shot is better exposed.
Posted on Jan 21, 2011
Sony cyber shot dsc h200 lens is stuck, will not take pictures. says to turn off and turn on again, but does not work.
Hi Susan,
If you cannot find the power button, just simply remove the battery wait for few seconds and put the battery back. What I assume of this behavior is 'If the coming out lens is obstructed by anything' the camera will show such error. If it does again, I would suggest calling Sony and getting their advice. Regards
Feb 27, 2014 | Sony Cyber-shot DSC-H200/B 20 Megapixel...
When turning camera on, it says turn the power off and on again
1. Could be a weak battery. 2. Press the delete, LCD power, and menu buttons while turning it on.
Feb 09, 2010 | Sony Cyber-shot 10.1-Megapixel Digital...
Camera will not turn on and battery indicator displays battery is fully charged. Canon Powershot G6
You need to clean the battery contacts with a Q-Tip dampened in rubbing alcohol inside the battery compartment. Also clean the battery itself and the charger. Thanks, Dana
Sep 30, 2009 | Canon PowerShot G6 Digital Camera
I have a Canon Power Shot. I turn it on and then
Try a different battery anyway. I had the same problem with a Kodak a couple years ago. I put in a new battery and it started working fine.
Sep 08, 2009 | Canon Cameras
Canon PowerShot G6 Stopped Working
no, there is not an internal battery in canon g6 for operating it.
probably the battery does not touch the internal connectors of the camera.
May 10, 2008 | Canon PowerShot G6 Digital Camera
Canon Power Shot S2 IS Digital camera does not turn on
Call Canon tech support. It's free support and you may end up coming out cheaper by upgrading your camera through their Canon Loyalty program than having it repaired.
Mar 22, 2008 | Canon PowerShot S2 IS Digital Camera
Open Questions:
See all Canon "infrared" Power Shot G6 7.1 Mp Digital Questions
Canon "infrared" Power Shot G6 7.1 Mp Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
